[GRASS-dev] trying to compile wxPython NVIZ
Glynn Clements
glynn at gclements.plus.com
Tue Jul 15 01:56:28 EDT 2008
Martin Landa wrote:
> >> /Users/cmbarton/grass_dev/grass7_src/lib/nviz
> >> /Users/cmbarton/grass_dev/grass7_src/gui/wxpython/vdigit
> >> /Users/cmbarton/grass_dev/grass7_src/gui/wxpython/nviz
> >> /Users/cmbarton/grass_dev/grass7_src/visualization/nviz2/cmd
> >> I went to /lib/nviz to check out the error. The result is below. It is
> >> different from the last time it didn't compile, so I hope that this
> >> means that it's getting closer. I'm copying William and Glynn to see
> >> if anyone has suggestions for how to get this working on my Mac. I am
> >> very much looking forward to trying this out.
> > lib/nviz/Makefile should have $(OGSFLIB) added to EXTRA_LIBS.
> done, http://trac.osgeo.org/grass/changeset/32112
> Anyway, off-screen rendering is still unsolved on Mac. To try wxGUI
> Nviz extension, you should be able to compile nvizlib without rendec.c
> (which is not needed for wxGUI).
If you have to explicitly disable render.c, that suggests that
something needs to be conditionalised. The code should at least
compile on all platforms, even if it doesn't work.
If you can't fix the compilation issues yourself, please post the
error messages to the list.
