[GRASS-dev] trying to compile wxPython NVIZ
William Kyngesburye
woklist at kyngchaos.com
Wed Jul 16 10:13:42 EDT 2008
I got further now. By ignoring render.c, libnviz compiles.
Now I'm in wxpython/nviz. I see that there is still the nviz header
include order problem here. In wxpython nviz.h, the order should be:
extern "C" {
#include <grass/gis.h>
#include <grass/nviz.h>
#include <grass/gsurf.h>
#include <grass/gstypes.h>
And I see one in nviz.i:
#include "nviz.h"
Now I get an error in the swig wrapper:
c++ -I/Users/Shared/src/GRASS/svn/trunk/dist.i386-apple-darwin9.3.0/
include -Os -fno-common -I/Library/Frameworks/GDAL.framework/
Versions/1.5/Headers -I/System/Library/Frameworks/Python.framework/
Versions/2.5/include/python2.5 -I/System/Library/Frameworks/
Python.framework/Versions/2.5/include/python2.5 -fno-strict-aliasing -
Wno-long-double -no-cpp-precomp -mno-fused-madd -fno-common -dynamic -
DNDEBUG -g -Os -Wall -Wstrict-prototypes -DMACOSX -I/usr/include/ffi -
DENABLE_DTRACE -I/usr/lib/wx/include/mac-unicode-debug-2.8 -I/usr/
include/wx-2.8 -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D__WXDEBUG__ -
D__WXMAC__ -DPACKAGE=\""grasslibs"\" -I/Users/Shared/src/GRASS/
svn/trunk/dist.i386-apple-darwin9.3.0/include -o OBJ.i386-apple-
darwin9.3.0/grass7_wxnviz_wrap.o -c grass7_wxnviz_wrap.cpp
cc1plus: warning: command line option "-Wstrict-prototypes" is valid
for C/ObjC but not for C++
/usr/include/wx-2.8/wx/mac/carbon/glcanvas.h:49: warning:
‘AGLDrawable’ is deprecated (declared at /System/Library/Frameworks/
AGL.framework/Headers/agl.h:61)
/usr/include/wx-2.8/wx/mac/carbon/glcanvas.h:53: warning:
grass7_wxnviz_wrap.cpp:3165: error: expected unqualified-id before ‘{’
token
grass7_wxnviz_wrap.cpp:3173: error: expected unqualified-id before ‘{’
token
grass7_wxnviz_wrap.cpp:3180: error: expected unqualified-id before ‘{’
token
grass7_wxnviz_wrap.cpp:3241: error: expected unqualified-id before ‘{’
token
grass7_wxnviz_wrap.cpp:3781: error: expected unqualified-id before ‘{’
token
grass7_wxnviz_wrap.cpp: In static member function ‘static int
swig::traits_asptr_stdseq<Seq, T>::asptr(PyObject*, Seq**)’:
grass7_wxnviz_wrap.cpp:3889: error: expected unqualified-id before ‘?’
token
make: *** [OBJ.i386-apple-darwin9.3.0/grass7_wxnviz_wrap.o] Error 1
The relevant lines (first case):
template <class Type>
struct traits_check<Type, value_category> {
static bool check(PyObject *obj) {
int res = obj ? asval(obj, (Type *)(0)) : SWIG_ERROR;
return SWIG_IsOK(res) ? true : false;
It's the check(PyObject) line. All the other errors are also on
check(PyObject) lines (except that last one), which is:
return pyseq.check() ? SWIG_OK : SWIG_ERROR;
I'm using the SWIG included in OSX Xcode 3.1: v1.3.31.
On Jul 16, 2008, at 8:33 AM, William Kyngesburye wrote:
> On Jul 16, 2008, at 2:45 AM, Glynn Clements wrote:
>> According to:
>> http://developer.apple.com/documentation/GraphicsImaging/Reference/AGL_OpenGL/Reference/reference.html
>> it should be AGLPixelFormat (without the "ID" suffix).
>> And that's exactly what togl.c uses.
> That works, but now it chokes on AGLPixmap...
>> Also, I note that aglCreateAGLPixmap isn't mentioned on that page.
>> However, it does describe aglCreatePBuffer, which is probably the
>> appropriate function to use (similarly, the X11 implementation should
>> probably use pBuffers if they are available).
> ... so I wonder if "AGLPixmap windowId;" should also be changed to
> "AGLPbuffer windowId;"?
> Doing that works. But I imagine that the rest of the nviz library
> must be changed to use AGLPbuffers.
> I didn't get errors elsewhere about missing AGL pixmap functions. I
> only see those in render.c, which I disabled to be able to compile
> libnviz.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
