[GRASS-dev] Python Scripting
Michael Barton
michael.barton at asu.edu
Sat Jul 19 16:14:30 EDT 2008
I can see how it could be handy to be able to access GRASS library
functions from Python. Would this differ from the Python SWIG
interface? I thought that SWIG was supposed to allow this?
Or maybe I misunderstand. Sorry if I am missing something.
Michael
On Jul 18, 2008, at 3:29 PM, Dan D'Alimonte wrote:
> That's why I put it to the mailing list. I was picturing something
> that acted as an intermediate between the low-level, direct data
> access nature of the C library and the high-level nature of shell
> scripts, This could possibly easily allow access to both in the same
> program. In situations where shell scripts' limits make you jump
> through hoops and the C library is just too low-level, a solid
> Python library would be of use in developing GRASS programs. It
> could also allow for more people access to GRASS and GIS programming
> by providing a language with a much lower learning curve then C.
> As to whether it is needed or worth undertaking, that would be up to
> the community. What I put below was based on some periodic thoughts
> I've had in the past, but an actual design and implementation would
> need to be developed if there is enough interest. And if Python is
> indeed the right environment to do this in (I know speed of raster
> processing has already been brought up).
> -- Dan.
> Michael Barton wrote:
>> Hi Dan,
>> This sounds intriguing. What we need to ask is what would this gain
>> us and how much work would it take.
>> Michael
>> On Jul 17, 2008, at 9:00 AM, <grass-dev-request at lists.osgeo.org>
>> wrote:
>>> Date: Thu, 17 Jul 2008 11:23:58 -0400
>>> From: "Dan D'Alimonte" <dan at dalimonte.ca>
>>> Subject: Re: [GRASS-dev] Python Scripting
>>> To: grass-dev at lists.osgeo.org
>>> Message-ID: <487F640E.6030704 at dalimonte.ca>
>>> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>>> I'm curious if any though has been given to developing an actual
>>> GRASS
>>> library for Python that goes beyond calling executables with
>>> system calls?
>>> I'm thinking about a model that encapsulates the GRASS environment
>>> and
>>> allows for both low-level processing like the C library, and high-
>>> level
>>> use of existing modules like shell scripts.
>>> I'll admit I have not given this a lot of though, but a
>>> hypothetical,
>>> and quickly thought-out, example could be something like:
>>> from grass import module, layer, cell, parser
>>> def r_add(inLayers, outLayer):
>>> for outCell in outLayer.cells:
>>> sum = cell(type=outLayer.cellType)
>>> for l in inLayers:
>>> c = l.getCellAtSameLocation(outCell)
>>> if c.value==cell.null:
>>> sum.value = cell.null
>>> break
>>> sum.value += c.value
>>> outCell.value = c.value
>>> outLayer.commit()
>>> if __name__ == "__main__":
>>> # Set up module information here
>>> # Set up and run parser
>>> # Open input layers
>>> # Create new layer for output
>>> # call r_add()
>>> # close layers
>>> I don't know if this would even be feasible, but I think it would
>>> make a
>>> nice addition to GRASS's Python support. If done right it would even
>>> allow other python-based GRASS modules to be called-on without
>>> having to
>>> make a system-call (eg. from raster_add import r_add).
>>> As to existing modules, what about a helper function to access then?
>>> module.executeModule( name="r.stats", options={ "input":
>>> "elevation.dem,slope,aspect", "fs": ",", "output": "elev.csv"},
>>> flags=["q", "1", "n", "g"] )
>>> It was just a thought, and would require a lot more thought and
>>> work to
>>> design properly. I, frankly, do not have enough understanding of
>>> GRASS
>>> internals to even know where to begin.
>> grass-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
