[GRASS-dev] Python Scripting
Dan D'Alimonte
dan at dalimonte.ca
Mon Jul 21 10:52:55 EDT 2008
Having never used SWIG, my understanding was it gives you access to the
functions in the C library? This is a good thing, yes, but I was
thinking of something beyond this. As I stated earlier, to allow
programming for GRASS at a higher level the the C functions, including
making use of Python's Object Oriented features to encapsulate GRASS
data structures and processes. For example, a RasterLayer class that
contains raster data, with it associated spatial characteristics, that
can provide interators over rows of cells, columns of cells, individual
cells, or moving windows such as a 3x3 matrix.
And apologies in return if I've been unclear.
Michael Barton wrote:
> I can see how it could be handy to be able to access GRASS library
> functions from Python. Would this differ from the Python SWIG interface?
> I thought that SWIG was supposed to allow this?
> Or maybe I misunderstand. Sorry if I am missing something.
> Michael
> On Jul 18, 2008, at 3:29 PM, Dan D'Alimonte wrote:
>> That's why I put it to the mailing list. I was picturing something
>> that acted as an intermediate between the low-level, direct data
>> access nature of the C library and the high-level nature of shell
>> scripts, This could possibly easily allow access to both in the same
>> program. In situations where shell scripts' limits make you jump
>> through hoops and the C library is just too low-level, a solid Python
>> library would be of use in developing GRASS programs. It could also
>> allow for more people access to GRASS and GIS programming by providing
>> a language with a much lower learning curve then C.
>> As to whether it is needed or worth undertaking, that would be up to
>> the community. What I put below was based on some periodic thoughts
>> I've had in the past, but an actual design and implementation would
>> need to be developed if there is enough interest. And if Python is
>> indeed the right environment to do this in (I know speed of raster
>> processing has already been brought up).
>> -- Dan.
