[GRASS-dev] Python script test
Glynn Clements
glynn at gclements.plus.com
Sun Jul 20 05:43:59 EDT 2008
Michael Barton wrote:
> I just posted a new Python version of the r.in.aster script. It is
> called r_in_aste.py and is currently residing in GRASS7/scripts/
> r.in.aster.
> If you'd like to try it, it needs Python of course (2.4 or above), and
> wxPython (2.7 or above).
AFAICT, it doesn't need wxPython.
A couple of suggestions and comments:
1. Wrap subprocess.call("g.message") in their own functions.
Ultimately, these are candidates for moving into the grass module.
Possibly, they should be replaced with Python code, or a call (via
SWIG) to the GRASS library functions.
2. Use a dictionary for the band names, rather than a conditional.
3. Don't redirect stderr to a pipe without reason. In particular,
don't redirect it if you aren't going to read it, as the child will
deadlock if it writes more than a buffer's worth of data to stderr.
4. For the equivalent of backticks, use p.communicate()[0] rather than
p.stdout.read(), as the former will consume stderr, and also wait()
for the child to terminate (otherwise you end up with zombie
processes).
5. I'm not sure that there's any point in using g.tempfile in Python
scripts.
I've attached a version which implements most of the above, and which
also uses an updated version of the grass.py module.
#!/usr/bin/python
# MODULE: r_in_aster.py
# AUTHOR(S): Michael Barton (michael.barton at asu.edu)
# Based on r.in.aster bash script for GRASS
# by Michael Barton and Paul Kelly
# PURPOSE: Rectifies, georeferences, & imports Terra-ASTER imagery
# using gdalwarp
# COPYRIGHT: (C) 2008 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
# Requires:
# gdalwarp
#%Module
#% description: Georeference, rectify, and import Terra-ASTER imagery and relative DEM's using gdalwarp.
#% keywords: raster, imagery, import
#%End
#%option
#% key: input
#% type: string
#% gisprompt: old_file,file,input
#% description: Input ASTER image to be georeferenced & rectified
#% required: yes
#%end
#%option
#% key: proctype
#% type: string
#% description: ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)
#% options: L1A,L1B,DEM
#% answer: L1B
#% required: yes
#%end
#%option
#% key: band
#% type: string
#% description: List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate all bands
#% answer: all
#% required: yes
#%end
#%option
#% key: output
#% type: string
#% description: Base name for output raster map (band number will be appended to base name)
#% gisprompt: old,cell,raster
#% required: yes
#%end
#%flag
#% key: o
#% description: Overwrite existing file
#%END
import sys
import os
import subprocess
import platform
import grass
bands = {
'L1A': {
'1': "VNIR_Band1:ImageData",
'2': "VNIR_Band2:ImageData",
'3n': "VNIR_Band3N:ImageData",
'3b': "VNIR_Band3B:ImageData",
'4': "SWIR_Band4:ImageData",
'5': "SWIR_Band5:ImageData",
'6': "SWIR_Band6:ImageData",
'7': "SWIR_Band7:ImageData",
'8': "SWIR_Band8:ImageData",
'9': "SWIR_Band9:ImageData",
'10': "TIR_Band10:ImageData",
'11': "TIR_Band11:ImageData",
'12': "TIR_Band12:ImageData",
'13': "TIR_Band13:ImageData",
'14': "TIR_Band14:ImageData"
'L1B': {
'1': "VNIR_Swath:ImageData1",
'2': "VNIR_Swath:ImageData2",
'3n': "VNIR_Swath:ImageData3N",
'3b': "VNIR_Swath:ImageData3B",
'4': "SWIR_Swath:ImageData4",
'5': "SWIR_Swath:ImageData5",
'6': "SWIR_Swath:ImageData6",
'7': "SWIR_Swath:ImageData7",
'8': "SWIR_Swath:ImageData8",
'9': "SWIR_Swath:ImageData9",
'10': "TIR_Swath:ImageData10",
'11': "TIR_Swath:ImageData11",
'12': "TIR_Swath:ImageData12",
'13': "TIR_Swath:ImageData13",
'14': "TIR_Swath:ImageData14"
def _message(msg, *args):
subprocess.call(["g.message", "message=%s" % msg] + list(args))
def debug(msg):
_message(msg, '-d')
def message(msg):
_message(msg)
def error(msg):
_message(msg, '-e')
sys.exit(1)
def main():
#check whether gdalwarp is in path and executable
p = None
try:
p = subprocess.call(['gdalwarp', '--version'])
except:
pass
if p == None or p != 0:
error("gdalwarp is not in the path and executable")
#initialize variables
dataset = ''
srcfile = ''
proj = ''
band = ''
outfile = ''
bandlist = []
#create temporary file to hold gdalwarp output before importing to GRASS
tempfile = grass.read_command("g.tempfile", pid = os.getpid()).strip() + '.tif'
#get projection information for current GRASS location
proj = grass.read_command('g.proj', flags = 'jf').strip()
#currently only runs in projected location
if "XY location" in proj:
error ("This module needs to be run in a projected location (found: %s)" % proj)
#process list of bands
if options['band'].strip() == 'all':
bandlist = ['1','2','3n','3b','4','5','6','7','8','9','10','11','12','13','14']
else:
bandlist = options['band'].split(',')
print 'bandlist =',bandlist
#initialize datasets for L1A and L1B
if options['proctype'] in ["L1A", "L1B"]:
for band in bandlist:
dataset = bands[options['proctype']][band]
srcfile = "HDF4_EOS:EOS_SWATH:%s:%s" % (options['input'], dataset)
import_aster(proj, srcfile, tempfile, band)
elif options['proctype'] == "DEM":
srcfile=options['input']
import_aster(proj, srcfile, tempfile, "DEM")
#for debugging
#print 'source file=',srcfile
#print 'tempfile=',tempfile
#print 'proj =',proj
# write cmd history: Not sure how to replicate this in Python yet
#r.support "$GIS_OPT_OUTPUT" history="${CMDLINE}"
#cleanup
message("Cleaning up ...")
os.remove(tempfile)
message("Done.")
return
def import_aster(proj, srcfile, tempfile, band):
#run gdalwarp with selected options (must be in $PATH)
#to translate aster image to geotiff
message("Georeferencing aster image ...")
debug("gdalwarp -t_srs %s %s %s" % (proj, srcfile, tempfile))
if platform.system() == "Darwin":
cmd = ["arch", "-i386", "gdalwarp", "-t_srs", proj, srcfile, tempfile ]
else:
cmd = ["gdalwarp", "-t_srs", proj, srcfile, tempfile ]
p = subprocess.call(cmd)
if p != 0:
#check to see if gdalwarp executed properly
return
#p = subprocess.call(["gdal_translate", srcfile, tempfile])
#import geotiff to GRASS
message("Importing into GRASS ...")
outfile = options['output'].strip()+'.'+band
grass.run_command("r.in.gdal", overwrite = flags['o'], input = tempfile, output = outfile)
return
if __name__ == "__main__":
options, flags = grass.parser()
main()
import os
import os.path
import sys
import types
import subprocess
def _make_val(val):
if isinstance(val, types.StringType):
return val
if isinstance(val, types.ListType):
return ",".join(map(_make_val, val))
if isinstance(val, types.TupleType):
return _make_val(list(val))
return str(val)
def make_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **options):
args = [prog]
if overwrite:
args.append("--o")
if quiet:
args.append("--q")
if verbose:
args.append("--v")
if flags:
args.append("-%s" % flags)
for opt, val in options.iteritems():
args.append("%s=%s" % (opt, _make_val(val)))
return args
def start_command(prog, flags = "", overwrite = False, quiet = False, verbose = False, **kwargs):
options = {}
popts = {}
for opt, val in kwargs.iteritems():
if opt in ["bufsize", "executable", "stdin", "stdout", "stderr",
"preexec_fn", "close_fds", "cwd", "env",
"universal_newlines", "startupinfo", "creationflags"]:
popts[opt] = val
else:
options[opt] = val
args = make_command(prog, flags, overwrite, quiet, verbose, **options)
return subprocess.Popen(args, **popts)
def run_command(*args, **kwargs):
ps = start_command(*args, **kwargs)
return ps.wait()
def read_command(*args, **kwargs):
kwargs['stdout'] = subprocess.PIPE
return ps.communicate()[0]
def _parse_env():
options = {}
flags = {}
for var, val in os.environ.iteritems():
if var.startswith("GIS_OPT_"):
opt = var.replace("GIS_OPT_", "", 1).lower()
options[opt] = val;
if var.startswith("GIS_FLAG_"):
flg = var.replace("GIS_FLAG_", "", 1).lower()
flags[flg] = bool(int(val));
return (options, flags)
def parser():
if not os.getenv("GISBASE"):
print >> sys.stderr, "You must be in GRASS GIS to run this program."
sys.exit(1)
if len(sys.argv) > 1 and sys.argv[1] == "@ARGS_PARSED@":
return _parse_env()
argv = sys.argv[:]
name = argv[0]
if not os.path.isabs(name):
argv[0] = os.path.normpath(os.path.join(sys.path[0], name))
os.execvp("g.parser", [name] + argv)
raise OSError("error executing g.parser")
