[GRASS-dev] Python script test
Michael Barton
michael.barton at asu.edu
Sun Jul 20 13:20:02 EDT 2008
Thanks very much Glynn!!!
These are excellent suggestions AND shows the potential of Python for
scripting.
I haven't tried this without wxPython, but I thought it was needed for
the parser code. I'll test it with GRASS 6.4
I also wondered about using g.tempfile. The only reason to use it that
I can think of is that the temp file ends up in a GRASS mapset rather
than the global gmp directory.
Michael
On Jul 20, 2008, at 2:43 AM, Glynn Clements wrote:
> Michael Barton wrote:
>> I just posted a new Python version of the r.in.aster script. It is
>> called r_in_aste.py and is currently residing in GRASS7/scripts/
>> r.in.aster.
>> If you'd like to try it, it needs Python of course (2.4 or above),
>> and
>> wxPython (2.7 or above).
> AFAICT, it doesn't need wxPython.
> A couple of suggestions and comments:
> 1. Wrap subprocess.call("g.message") in their own functions.
> Ultimately, these are candidates for moving into the grass module.
> Possibly, they should be replaced with Python code, or a call (via
> SWIG) to the GRASS library functions.
> 2. Use a dictionary for the band names, rather than a conditional.
> 3. Don't redirect stderr to a pipe without reason. In particular,
> don't redirect it if you aren't going to read it, as the child will
> deadlock if it writes more than a buffer's worth of data to stderr.
> 4. For the equivalent of backticks, use p.communicate()[0] rather than
> p.stdout.read(), as the former will consume stderr, and also wait()
> for the child to terminate (otherwise you end up with zombie
> processes).
> 5. I'm not sure that there's any point in using g.tempfile in Python
> scripts.
> I've attached a version which implements most of the above, and which
> also uses an updated version of the grass.py module.
> Glynn Clements <glynn at gclements.plus.com>
> #!/usr/bin/python
> # MODULE: r_in_aster.py
> # AUTHOR(S): Michael Barton (michael.barton at asu.edu)
> # Based on r.in.aster bash script for GRASS
> # by Michael Barton and Paul Kelly
> # PURPOSE: Rectifies, georeferences, & imports Terra-ASTER
> imagery
> # using gdalwarp
> # COPYRIGHT: (C) 2008 by the GRASS Development Team
> # This program is free software under the GNU General Public
> # License (>=v2). Read the file COPYING that comes with GRASS
> # for details.
> # Requires:
> # gdalwarp
> #%Module
> #% description: Georeference, rectify, and import Terra-ASTER
> imagery and relative DEM's using gdalwarp.
> #% keywords: raster, imagery, import
> #%End
> #%option
> #% key: input
> #% type: string
> #% gisprompt: old_file,file,input
> #% description: Input ASTER image to be georeferenced & rectified
> #% required: yes
> #%end
> #%option
> #% key: proctype
> #% type: string
> #% description: ASTER imagery processing type (Level 1A, Level 1B,
> or relative DEM)
> #% options: L1A,L1B,DEM
> #% answer: L1B
> #% required: yes
> #%end
> #%option
> #% key: band
> #% type: string
> #% description: List L1A or L1B band to translate (1,2,3n,...), or
> enter 'all' to translate all bands
> #% answer: all
> #% required: yes
> #%end
> #%option
> #% key: output
> #% type: string
> #% description: Base name for output raster map (band number will
> be appended to base name)
> #% gisprompt: old,cell,raster
> #% required: yes
> #%end
> #%flag
> #% key: o
> #% description: Overwrite existing file
> #%END
> import sys
> import os
> import subprocess
> import platform
> import grass
> bands = {
> 'L1A': {
> '1': "VNIR_Band1:ImageData",
> '2': "VNIR_Band2:ImageData",
> '3n': "VNIR_Band3N:ImageData",
> '3b': "VNIR_Band3B:ImageData",
> '4': "SWIR_Band4:ImageData",
> '5': "SWIR_Band5:ImageData",
> '6': "SWIR_Band6:ImageData",
> '7': "SWIR_Band7:ImageData",
> '8': "SWIR_Band8:ImageData",
> '9': "SWIR_Band9:ImageData",
> '10': "TIR_Band10:ImageData",
> '11': "TIR_Band11:ImageData",
> '12': "TIR_Band12:ImageData",
> '13': "TIR_Band13:ImageData",
> '14': "TIR_Band14:ImageData"
> 'L1B': {
> '1': "VNIR_Swath:ImageData1",
> '2': "VNIR_Swath:ImageData2",
> '3n': "VNIR_Swath:ImageData3N",
> '3b': "VNIR_Swath:ImageData3B",
> '4': "SWIR_Swath:ImageData4",
> '5': "SWIR_Swath:ImageData5",
> '6': "SWIR_Swath:ImageData6",
> '7': "SWIR_Swath:ImageData7",
> '8': "SWIR_Swath:ImageData8",
> '9': "SWIR_Swath:ImageData9",
> '10': "TIR_Swath:ImageData10",
> '11': "TIR_Swath:ImageData11",
> '12': "TIR_Swath:ImageData12",
> '13': "TIR_Swath:ImageData13",
> '14': "TIR_Swath:ImageData14"
> def _message(msg, *args):
> subprocess.call(["g.message", "message=%s" % msg] + list(args))
> def debug(msg):
> _message(msg, '-d')
> def message(msg):
> _message(msg)
> def error(msg):
> _message(msg, '-e')
> sys.exit(1)
> def main():
> #check whether gdalwarp is in path and executable
> p = None
> try:
> p = subprocess.call(['gdalwarp', '--version'])
> except:
> pass
> if p == None or p != 0:
> error("gdalwarp is not in the path and executable")
> #initialize variables
> dataset = ''
> srcfile = ''
> proj = ''
> band = ''
> outfile = ''
> bandlist = []
> #create temporary file to hold gdalwarp output before importing
> to GRASS
> tempfile = grass.read_command("g.tempfile", pid =
> os.getpid()).strip() + '.tif'
> #get projection information for current GRASS location
> proj = grass.read_command('g.proj', flags = 'jf').strip()
> #currently only runs in projected location
> if "XY location" in proj:
> error ("This module needs to be run in a projected location
> (found: %s)" % proj)
> #process list of bands
> if options['band'].strip() == 'all':
> bandlist =
> ['1','2','3n','3b','4','5','6','7','8','9','10','11','12','13','14']
> else:
> bandlist = options['band'].split(',')
> print 'bandlist =',bandlist
> #initialize datasets for L1A and L1B
> if options['proctype'] in ["L1A", "L1B"]:
> for band in bandlist:
> dataset = bands[options['proctype']][band]
> srcfile = "HDF4_EOS:EOS_SWATH:%s:%s" % (options['input'],
> dataset)
> import_aster(proj, srcfile, tempfile, band)
> elif options['proctype'] == "DEM":
> srcfile=options['input']
> import_aster(proj, srcfile, tempfile, "DEM")
> #for debugging
> #print 'source file=',srcfile
> #print 'tempfile=',tempfile
> #print 'proj =',proj
> # write cmd history: Not sure how to replicate this in Python yet
> #r.support "$GIS_OPT_OUTPUT" history="${CMDLINE}"
> #cleanup
> message("Cleaning up ...")
> os.remove(tempfile)
> message("Done.")
> return
> def import_aster(proj, srcfile, tempfile, band):
> #run gdalwarp with selected options (must be in $PATH)
> #to translate aster image to geotiff
> message("Georeferencing aster image ...")
> debug("gdalwarp -t_srs %s %s %s" % (proj, srcfile, tempfile))
> if platform.system() == "Darwin":
> cmd = ["arch", "-i386", "gdalwarp", "-t_srs", proj, srcfile,
> tempfile ]
> else:
> cmd = ["gdalwarp", "-t_srs", proj, srcfile, tempfile ]
> p = subprocess.call(cmd)
> if p != 0:
> #check to see if gdalwarp executed properly
> return
> #p = subprocess.call(["gdal_translate", srcfile, tempfile])
> #import geotiff to GRASS
> message("Importing into GRASS ...")
> outfile = options['output'].strip()+'.'+band
> grass.run_command("r.in.gdal", overwrite = flags['o'], input =
> tempfile, output = outfile)
> return
> if __name__ == "__main__":
> options, flags = grass.parser()
> main()
> import os
> import os.path
> import sys
> import types
> import subprocess
> def _make_val(val):
> if isinstance(val, types.StringType):
> return val
> if isinstance(val, types.ListType):
> return ",".join(map(_make_val, val))
> if isinstance(val, types.TupleType):
> return _make_val(list(val))
> return str(val)
> def make_command(prog, flags = "", overwrite = False, quiet = False,
> verbose = False, **options):
> args = [prog]
> if overwrite:
> args.append("--o")
> if quiet:
> args.append("--q")
> if verbose:
> args.append("--v")
> if flags:
> args.append("-%s" % flags)
> for opt, val in options.iteritems():
> args.append("%s=%s" % (opt, _make_val(val)))
> return args
> def start_command(prog, flags = "", overwrite = False, quiet =
> False, verbose = False, **kwargs):
> options = {}
> popts = {}
> for opt, val in kwargs.iteritems():
> if opt in ["bufsize", "executable", "stdin", "stdout", "stderr",
> "preexec_fn", "close_fds", "cwd", "env",
> "universal_newlines", "startupinfo", "creationflags"]:
> popts[opt] = val
> else:
> options[opt] = val
> args = make_command(prog, flags, overwrite, quiet, verbose,
> **options)
> return subprocess.Popen(args, **popts)
> def run_command(*args, **kwargs):
> ps = start_command(*args, **kwargs)
> return ps.wait()
> def read_command(*args, **kwargs):
> kwargs['stdout'] = subprocess.PIPE
> return ps.communicate()[0]
> def _parse_env():
> options = {}
> flags = {}
> for var, val in os.environ.iteritems():
> if var.startswith("GIS_OPT_"):
> opt = var.replace("GIS_OPT_", "", 1).lower()
> options[opt] = val;
> if var.startswith("GIS_FLAG_"):
> flg = var.replace("GIS_FLAG_", "", 1).lower()
> flags[flg] = bool(int(val));
> return (options, flags)
> def parser():
> if not os.getenv("GISBASE"):
> print >> sys.stderr, "You must be in GRASS GIS to run this
> program."
> sys.exit(1)
> if len(sys.argv) > 1 and sys.argv[1] == "@ARGS_PARSED@":
> return _parse_env()
> argv = sys.argv[:]
> name = argv[0]
> if not os.path.isabs(name):
> argv[0] = os.path.normpath(os.path.join(sys.path[0], name))
> os.execvp("g.parser", [name] + argv)
> raise OSError("error executing g.parser")
