[GRASS-dev] g.region -g crashes in a latlon location
Maciej Sieczka
tutey at o2.pl
Mon Jul 21 03:25:30 EDT 2008
Glynn Clements pisze:
> Maciej Sieczka wrote:
>> I have just noticed that g.region -g or -p crashes in a latlon
>> location. Example:
>> 0x00007f33d130f69e in sincos (val=0.90594848802138783,
>> sin_val=0x7fffda923030, cos_val=0x7fffda923028) at GDapi.c:6265
>> 6265 *sin_val = sin(val); (gdb) bt #0 0x00007f33d130f69e in
>> sincos (val=0.90594848802138783, sin_val=0x7fffda923030,
>> cos_val=0x7fffda923028) at GDapi.c:6265 #1 0x00007f33d130f6a3 in
>> sincos (val=0.90594848802138783, sin_val=0x7fffda923060,
>> cos_val=0x7fffda923058) at GDapi.c:6265 #2 0x00007f33d130f6a3 in
>> sincos (val=0.90594848802138783, sin_val=0x7fffda923090,
>> cos_val=0x7fffda923088) at GDapi.c:6265
>> (The whole backtrace is all very long.)
> When you say "very long", is it actually finite? Or did you give up
> before reaching the end?
The latter. After reaching line #5473 in gdb I gave up.
> Because the line which the debugger shows:
> doesn't appear to be a recursive call, but the backtrace indicates an
> infinite "direct" recursion (i.e. the function calls itself with
> exactly the same arguments).
> My guess is that the saved frame pointer is actually pointing to the
> current frame, i.e. a linked list where "p->next == p".
> In any case, this doesn't help identify the real problem. Can you
> step through the g.region code from the beginning and find where in
> g.region (or the GRASS libraries) that it's going out of control?
If you can tell how to do it I'd try.
Can you reproduce the crash? Anybody else?
Maciek
P.S.
Here's GRASS debug output. Maybe it helps some:
D2/10: G__read_Cell_head
D2/10: G__read_Cell_head_array
D3/10: region item: proj: 3
D3/10: region item: zone: 0
D3/10: region item: north: 51N
D3/10: region item: south: 50N
D3/10: region item: east: 16E
D3/10: region item: west: 15E
D3/10: region item: cols: 1
D3/10: region item: rows: 1
D3/10: region item: e-w resol: 1
D3/10: region item: n-s resol: 1
D3/10: region item: top: 1
D3/10: region item: bottom: 0
D3/10: region item: cols3: 1
D3/10: region item: rows3: 1
D3/10: region item: depths: 1
D3/10: region item: e-w resol3: 1
D3/10: region item: n-s resol3: 1
D3/10: region item: t-b resol: 1
D3/10: G_adjust_Cell_head: epsilon_ns: 0.001, epsilon_ew: 1e-06
D3/10: region item: north: 52:00:01.5N
D3/10: region item: south: 50:59:58.5N
D3/10: region item: east: 17:00:01.5E
D3/10: region item: west: 14:59:58.5E
D3/10: region item: cols: 2401
D3/10: region item: rows: 1201
D3/10: region item: e-w resol: 0:00:03
D3/10: region item: n-s resol: 0:00:03
D3/10: region item: cols3: 2401
D3/10: region item: rows3: 1201
D3/10: region item: e-w resol3: 0:00:03
D3/10: region item: n-s resol3: 0:00:03
D3/10: G_adjust_Cell_head: epsilon_ns: 8.32639e-07, epsilon_ew: 1e-06
Segmentation fault
Maciej Sieczka
www.sieczka.org
