[GRASS-dev] g.region -g crashes in a latlon location
Yann Chemin
yann.chemin at gmail.com
Mon Jul 21 05:22:21 EDT 2008
I also have g.region -p crashing for about 2 weeks, cannot run tcltk
GUI and wxpython GUI because of that.
it does not say anything, on the segfault sentence...
2008/7/21 Maciej Sieczka <tutey at o2.pl>:
> Glynn Clements pisze:
>> Maciej Sieczka wrote:
>>> I have just noticed that g.region -g or -p crashes in a latlon
>>> location. Example:
>>> 0x00007f33d130f69e in sincos (val=0.90594848802138783,
>>> sin_val=0x7fffda923030, cos_val=0x7fffda923028) at GDapi.c:6265 6265
>>> *sin_val = sin(val); (gdb) bt #0 0x00007f33d130f69e in
>>> sincos (val=0.90594848802138783, sin_val=0x7fffda923030,
>>> cos_val=0x7fffda923028) at GDapi.c:6265 #1 0x00007f33d130f6a3 in
>>> sincos (val=0.90594848802138783, sin_val=0x7fffda923060,
>>> cos_val=0x7fffda923058) at GDapi.c:6265 #2 0x00007f33d130f6a3 in
>>> sincos (val=0.90594848802138783, sin_val=0x7fffda923090,
>>> cos_val=0x7fffda923088) at GDapi.c:6265
>>> (The whole backtrace is all very long.)
>> When you say "very long", is it actually finite? Or did you give up before
>> reaching the end?
> The latter. After reaching line #5473 in gdb I gave up.
>> Because the line which the debugger shows:
>>> 6265 *sin_val = sin(val);
>> doesn't appear to be a recursive call, but the backtrace indicates an
>> infinite "direct" recursion (i.e. the function calls itself with exactly
>> the same arguments).
>> My guess is that the saved frame pointer is actually pointing to the
>> current frame, i.e. a linked list where "p->next == p".
>> In any case, this doesn't help identify the real problem. Can you
>> step through the g.region code from the beginning and find where in
>> g.region (or the GRASS libraries) that it's going out of control?
> If you can tell how to do it I'd try.
> Can you reproduce the crash? Anybody else?
> Maciek
> P.S.
> Here's GRASS debug output. Maybe it helps some:
> D2/10: G__read_Cell_head
> D2/10: G__read_Cell_head_array
> D3/10: region item: proj: 3
> D3/10: region item: zone: 0
> D3/10: region item: north: 51N
> D3/10: region item: south: 50N
> D3/10: region item: east: 16E
> D3/10: region item: west: 15E
> D3/10: region item: cols: 1
> D3/10: region item: rows: 1
> D3/10: region item: e-w resol: 1
> D3/10: region item: n-s resol: 1
> D3/10: region item: top: 1
> D3/10: region item: bottom: 0
> D3/10: region item: cols3: 1
> D3/10: region item: rows3: 1
> D3/10: region item: depths: 1
> D3/10: region item: e-w resol3: 1
> D3/10: region item: n-s resol3: 1
> D3/10: region item: t-b resol: 1
> D3/10: G_adjust_Cell_head: epsilon_ns: 0.001, epsilon_ew: 1e-06
> D3/10: region item: north: 52:00:01.5N
> D3/10: region item: south: 50:59:58.5N
> D3/10: region item: east: 17:00:01.5E
> D3/10: region item: west: 14:59:58.5E
> D3/10: region item: cols: 2401
> D3/10: region item: rows: 1201
> D3/10: region item: e-w resol: 0:00:03
> D3/10: region item: n-s resol: 0:00:03
> D3/10: region item: cols3: 2401
> D3/10: region item: rows3: 1201
> D3/10: region item: e-w resol3: 0:00:03
> D3/10: region item: n-s resol3: 0:00:03
> D3/10: G_adjust_Cell_head: epsilon_ns: 8.32639e-07, epsilon_ew: 1e-06
> Segmentation fault
> Maciej Sieczka
> www.sieczka.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
