[GRASS-dev] g.region -g crashes in a latlon location
Glynn Clements
glynn at gclements.plus.com
Mon Jul 21 11:43:38 EDT 2008
Maciej Sieczka wrote:
> >>> In any case, this doesn't help identify the real problem. Can you
> >>> step through the g.region code from the beginning and find where in
> >>> g.region (or the GRASS libraries) that it's going out of control?
> >> If you can tell how to do it I'd try.
> Here's the result:
> Breakpoint 2, print_window (window=0x7fffd3fd5fe0, print_flag=3) at
> printwindow.c:9
> (gdb)
> 37 ew_dist1 =
> (gdb)
> Program received signal SIGSEGV, Segmentation fault.
> 0x00007fa1ca1c369e in sincos (val=0.90594848802138783,
> sin_val=0x7fffd37d7030, cos_val=0x7fffd37d7028) at GDapi.c:6265
> 6265 *sin_val = sin(val);
> (gdb)
Okay, the full statement is:
ew_dist1 =
G_distance(window->east, window->north, window->west, window->north);
The next step would be to set a breakpoint on G_distance, and repeat.
But I already know that will lead to G_geodesic_distance().
Below that, there isn't actually anything which can cause a segfault.
So, it's very much looking like a broken system.
