[GRASS-dev] debugging nviz with TclTk 8.5 aqua
Michael Barton
michael.barton at asu.edu
Tue Jul 22 21:35:49 EDT 2008
On Jul 22, 2008, at 6:29 PM, Glynn Clements wrote:
> Michael Barton wrote:
>>>> (gdb) print ((MacDrawable *) (window))
>>>> No symbol "MacDrawable" in current context.
>>> Hmm; does this work:
>>> print ((struct TkWindowPrivate *) (window))
>>> print ((struct TkWindowPrivate *) (window))->toplevel
>>> print ((struct TkWindowPrivate *) (window))->toplevel->grafPtr
>>> Failing that, just:
>>> print window
>>> might provide a clue.
>>> OTOH, I'm not sure if any of this will actually help in the end. The
>>> conclusion may well just be "Togl doesn't work with 8.5". I can't
>>> see
>>> any references to 8.5 on the Togl site (it isn't a particularly
>>> active
>>> project).
>> This actually produced some results.
>> (gdb) print ((struct TkWindowPrivate *) (window))
>> $1 = (struct TkWindowPrivate *) 0x1d7c648
>> (gdb) print ((struct TkWindowPrivate *) (window))->toplevel
>> $2 = (struct TkWindowPrivate *) 0x28
> Ouch.
> Do you have more than one version of Tcl/Tk on your system? One
> possibility is that the tkMacOSXInt.h header which Togl is using
> doesn't match the library.
> Another possibility is that the structure packing could be affected by
> compiler switches, so if Togl isn't compiled with the same switches as
> the Tk library, it won't be accessing the fields correctly.
> Can you try:
> print *((struct TkWindowPrivate *) (window))
Program received signal EXC_BAD_ACCESS, Could not access memory.
Reason: KERN_PROTECTION_FAILURE at address: 0x0000002c
0x0001702d in Togl_CreateWindow (tkwin=0x5cf0608, parent=97384328,
instanceData=0x757dc0) at togl.c:2338
2338 if (!aglSetDrawable(togl->aglCtx,
(gdb) print *((struct TkWindowPrivate *) (window))
$1 = {
winPtr = 0x5cf0608,
grafPtr = 0x0,
context = 0x6c63542f,
rootControl = 0x0,
xOff = 0,
yOff = 7337416,
size = {
width = 1.02819154e-38,
height = 0
visRgn = 0x936b48,
aboveVisRgn = 0x0,
drawRect = {
origin = {
x = 6.97764217e+22,
y = 1.8089652e+25
size = {
width = 1.41764467e+22,
height = 1.63008877e-19
referenceCount = -271777041,
toplevel = 0x28,
flags = 97452040
(gdb)
Mac OS X 10.5 comes with TclTk aqua 8.4 and 8.5. But I also have to
install an x11 version that I compile (in /usr/local/tcltk) in order
to compile and run GRASS with the standard x11 tcltk.
Michael
