[GRASS-dev] debugging nviz with TclTk 8.5 aqua
Glynn Clements
glynn at gclements.plus.com
Wed Jul 23 08:17:00 EDT 2008
Michael Barton wrote:
> > Oh; while you're at it, can you post your tkMacOSXInt.h header?
> I've put it at <http://www.public.asu.edu/~cmbarton/files/tcltk/>
> This is for aqua and (I assume) for 8.5.
Yep; that's 8.5:
struct TkWindowPrivate {
TkWindow *winPtr; /* Ptr to tk window or NULL if Pixmap */
CGrafPtr grafPtr;
CGContextRef context;
ControlRef rootControl;
int xOff; /* X offset from toplevel window */
int yOff; /* Y offset from toplevel window */
CGSize size;
HIShapeRef visRgn; /* Visible region of window */
HIShapeRef aboveVisRgn; /* Visible region of window & its children */
CGRect drawRect; /* Clipped drawing rect */
int referenceCount; /* Don't delete toplevel until children are
* gone. */
struct TkWindowPrivate *toplevel;
/* Pointer to the toplevel datastruct. */
int flags; /* Various state see defines below. */
For 8.4.9, it looks like:
CGrafPtr grafPtr;
RgnHandle clipRgn; /* Visable region of window */
RgnHandle aboveClipRgn; /* Visable region of window & it's children */
* gone. */
struct TkWindowPrivate *toplevel; /* Pointer to the toplevel
* datastruct. */
> > Can you try:
> > print *((struct TkWindowPrivate *) (window))
Okay; decoding to hex and/or strings:
> (gdb) print *((struct TkWindowPrivate *) (window))
> $1 = {
> winPtr = 0x5cf0608,
> grafPtr = 0x0,
> context = 0x6c63542f, // = "/Tcl"
> rootControl = 0x0,
> xOff = 0,
> yOff = 7337416, // 0x006ff5c8
> size = {
> width = 1.02819154e-38, // 0x006ff5cc
> height = 0
> visRgn = 0x936b48,
> aboveVisRgn = 0x0,
> drawRect = {
> origin = {
> x = 6.97764217e+22, // 0x656c6966 = "file"
> y = 1.8089652e+25 // 0x696f6a20 = " joi"
> size = {
> width = 1.41764467e+22,// 0x6440206e = "n @d"
> height = 1.63008877e-19// 0x20407269 = "ir@ "
> referenceCount = -271777041,// 0xefcd02ef
> toplevel = 0x28,
> flags = 97452040 // 0x05cf0008
As raw data, that's:
0x05cf0608,
0,
0x6c63542f = "/Tcl"
0,
0,
0x006ff5c8
0x006ff5cc
0
0x0936b48,
0,
0x656c6966 = "file"
0x696f6a20 = " joi"
0x6440206e = "n @d"
0x20407269 = "ir@ "
0xefcd02ef
0x28,
0x05cf0008
If I map that to the 8.4 TkWindowPrivate structure:
TkWindow * winPtr = 0x5cf0608
CGrafPtr grafPtr = 0
ControlRef rootControl = 0x6c63542f = "/Tcl"
int xOff = 0
int yOff = 0
RgnHandle clipRgn = 0x006ff5c8
RgnHandle aboveClipRgn = 0x006ff5cc
int referenceCount = 0
struct ... * toplevel = 0x00936b48
int flags = 0
which looks quite sane (the rootControl field isn't initialised by
TkpMakeWindow(), so it isn't unusual that it contains garbage at this
point).
> Mac OS X 10.5 comes with TclTk aqua 8.4 and 8.5. But I also have to
> install an x11 version that I compile (in /usr/local/tcltk) in order
> to compile and run GRASS with the standard x11 tcltk.
I'd say it's a fairly safe bet that Togl is being compiled with the
8.5 headers but linked against the 8.4 library.
