[GRASS-dev] debugging nviz with TclTk 8.5 aqua
William Kyngesburye
woklist at kyngchaos.com
Wed Jul 23 20:40:24 EDT 2008
On Jul 23, 2008, at 7:16 PM, Michael Barton wrote:
> I also have TclTk libs in /usr/local/lib, but these are not links.
> Maybe I should delete them? I'm not sure if go to the x11 install
> that I need for compiling the 'normal' TclTk GUI (the one installed
> following your instructions in the README file with most files
> located in /usr/local/tcltk).
otool -L /usr/local/lib/libtk8.4.dylib
(or 8.5 if they are 8.5)
This will tell you if it's linked to X11.
>> Then just add --with-tcltk-libs=/usr/local/lib to your configure.
> Maybe --with-tcltk-libs=/usr/lib ??
NO. That's the system tcltk.
> What about the environmental setting for 8.5? Just not run it or set
> it to 8.4?
I just started looking at 8.5. What I found so far for the aqua
framework build:
- it includes the private headers we need by default, but in a
separate subfolder:
Tk.framework/PrivateHeaders
- it does NOT install /usr/local/lib symlinks. So to account for a
default tcltk aqua, we need to look into the configure idea I had
earlier.
- while they have 64bits working for an X11 build, they don't have it
working for an Aqua build, so we won't get a 64bit tcl-based nviz.
For an immediate fix:
Configure with the --with-tcltk-includes as:
--with-tcltk-includes="/Library/Frameworks/Tcl.framework/Headers /
Library/Frameworks/Tk.framework/Headers /Library/Frameworks/
Tk.framework/PrivateHeaders" --with-opengl=aqua
you can ignore --with-tcltk-libs. BEFORE make, edit include/make/
platform.make and replace the TCLTKLIBS line with:
TCLTKLIBS = -framework Tcl -framework Tk
then make.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
