[GRASS-dev] PYTHONPATH question
Michael Barton
michael.barton at asu.edu
Tue Jul 29 13:42:50 EDT 2008
On Jul 29, 2008, at 10:34 AM, William Kyngesburye wrote:
> On Jul 29, 2008, at 12:15 PM, Michael Barton wrote:
>> cmb-MBP-2:~ cmbarton$ ls -l /usr/bin/python
>> lrwxr-xr-x 1 root wheel 72 May 9 15:32 /usr/bin/python -> ../../
>> System/Library/Frameworks/Python.framework/Versions/2.5/bin/python
>> cmb-MBP-2:~ cmbarton$ ls -l /usr/local/bin/python
>> lrwxr-xr-x 1 root wheel 68 May 9 23:07 /usr/local/bin/python -
>> > ../../../Library/Frameworks/Python.framework/Versions/2.5/bin/
>> python
> They're each pointing to the right python.
Looking more closely, one is in...
and the other is in...
/System/Library/Frameworks/Python.framework/Versions/2.5/bin/python
Is one of these a System Python, or has MacPython shifted where it
installs?
Michael
>>> #!/usr/bin/env python
>> No. The ???? was just me questioning if I should use that format.
> So, it should work, and run Mac Python. Or did you not have that
> there before, and *now* it's working?
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Mon Dieu! but they are all alike. Cheating, murdering, lying,
> fighting, and all for things that the beasts of the jungle would not
> deign to possess - money to purchase the effeminate pleasures of
> weaklings. And yet withal bound down by silly customs that make
> them slaves to their unhappy lot while firm in the belief that they
> be the lords of creation enjoying the only real pleasures of
> existence....
> - the wisdom of Tarzan
