[GRASS-dev] Re: [GRASS GIS] #181: tac command missing in OSX
trac at osgeo.org
Wed Jun 4 20:20:06 EDT 2008
Reporter: kyngchaos | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.3.1
Component: default | Version: 6.3.0
Resolution: | Keywords: v.in.garmin, v.in.mapgen
Comment (by hamish):
William:
> tac is annoying in that it's part of a GNU bundle, core-utilities, I
> couldn't find only tac source. And my first quick-n-dirty attempt to
> compile it failed.
1gray:
> That's how most bundles work. One couldn't, e. g., easily compile r.what
> without compiling the rest of GRASS as well.
it's not like tac has many dependencies:
$ ldd `which tac`
linux-gate.so.1 => (0xffffe000)
libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0xb7e0b000)
/lib/ld-linux.so.2 (0xb7f5a000)
I assume it's a trivial C program. What's the complile error?
While not POSIX, I think tac will be widely available. I would still like
to hear from Cygwin/MSys/other platforms.. to me the fact that it hasn't
been moved out of Debian's hardcore minimalist coreutils is a good
anecdotal endorsement for wide availability.
fwiw, on Debian/etch:
$ tail -r foo
tail: invalid option -- r
Try `tail --help' for more information.
$ echo $?
1
A not so nice for the user idea is to abort with an error if tac is not
found.
Glynn:
> Off the top of my head, the only thing that I can think of is to prefix
> each line with the line number using e.g. awk, use "sort -r", then strip
> the line numbers.
awk would be a great solution as this is fed directly into that. But I
have no idea how to write that.
Here is where it is needed- create lines for 'v.in.ascii format=standard':
# add vertex counts
cat "${TMP}.gpst" | sed -e '1d' | tac | awk 'BEGIN { FS="\t" ; R=0 } \
$1=="T" { printf(" %.7f %.7f\n", $4, $3) ; ++R } ; \
$1=="" { printf("L %d 1\n", R) ; R=0 } END {;}' | tac >
"${TMP}.base"
another thing for the future is to remove the vertex count requirement in
the vector ascii file. I suppose it adds some level of error checking, but
the computer can count.
William:
> I wonder if some sort of requirement in GRASS 7 development would be a
good
> idea to stick to POSIX/SUS commands?
that is the current goal, but I see little reason to go nuts trying to be
very strict about that, e.g. for something like `which` that may not be
POSIX but is, literally, everywhere. ie the overwhelming common use
exemption.
for GRASS 7 the goal AFAIU is to replace shell scripts with more portable
Python scripts.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/181#comment:9>
