[GRASS-dev] Re: [GRASS GIS] #181: tac command missing in OSX
trac at osgeo.org
Thu Jun 5 17:00:09 EDT 2008
Reporter: kyngchaos | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.3.1
Component: default | Version: 6.3.0
Resolution: | Keywords: v.in.garmin, v.in.mapgen
Comment (by glynn):
Replying to [comment:9 hamish]:
> While not POSIX, I think tac will be widely available. I would still
like to hear from Cygwin/MSys/other platforms.
Cygwin has it. My MSys installation doesn't, but it's quite out of date
(it has separate textutils and fileutils; AFAICT, newer versions have
coreutils, which probably has it). I suspect that non-GNU systems (e.g.
Solaris) probably won't have it.
> Glynn:
> > Off the top of my head, the only thing that I can think of is to
prefix
> > each line with the line number using e.g. awk, use "sort -r", then
strip
> > the line numbers.
> awk would be a great solution as this is fed directly into that. But I
have no idea how to write that.
Replace:
... | tac | ...
with:
... | awk '{print NR,$0}' | sort -nr | sed 's/^[0-9]* //' | ...
> > I wonder if some sort of requirement in GRASS 7 development would be a
good
> > idea to stick to POSIX/SUS commands?
> that is the current goal, but I see little reason to go nuts trying to
be very strict about that, e.g. for something like `which` that may not be
POSIX but is, literally, everywhere. ie the overwhelming common use
exemption.
I don't see any reason to use "which" when "type" is mandated by POSIX.
Ticket URL: <https://trac.osgeo.org/grass/ticket/181#comment:10>
