[GRASS-dev] WinGRASS Plans
Markus Neteler
neteler at osgeo.org
Thu Jun 5 16:19:21 EDT 2008
On Thu, Jun 5, 2008 at 3:20 PM, <marco.pasetti at alice.it> wrote:
[ great stuff skipped]
> Since Windows users cannot build binaries by themselves, it would be good to
> build and distribute also the GRASS AddOns. I'm not sure now how to
> distribute them (even if I've got some WIP ideas), but I surely need to
> create a simple procedure to build and install them all in a separated
> directory, with a build procedure indipendent from the GRASS build procedure
> itself.
I feel that the *build* procedure is pretty dependent on the GRASS build
procedure. But that's no problem:
> Since now I built addons putting the sources in the GRASS source tree and
> adding the addons to build in the general make files (for example adding
> r.horizon into the list of building modules in /raster/Makefile). But if I
> put the addons sources outside the main GRASS source tree, I would need to
> change the paths from relative to absolute in each module, and then create a
> Makefile for each addon module... too much work for a frequent task! Any
> suggestions?
That's not needed. You can compile with:
cd grass-addons/raster/r.sun_horizon/
make MODULE_TOPDIR=$HOME/grass64/
This will compile it into the main GRASS code tree.
Markus
