[GRASS-dev] WinGRASS Plans
Marco Pasetti
marco.pasetti at alice.it
Thu Jun 5 19:03:57 EDT 2008
Markus,
> That's not needed. You can compile with:
> cd grass-addons/raster/r.sun_horizon/
> make MODULE_TOPDIR=$HOME/grass64/
> This will compile it into the main GRASS code tree.
very good! Thanks
the last thing I have to check (when I'll finish to build all) is where the
binaries will be created. I'll see when I'll try to build one.
Then I'll need to create a script to automatically build all the addons in
the repository. I will work on it.
Thanks,
Marco
