[GRASS-dev] storing full script as metadata
Mon Jun 9 04:57:46 EDT 2008
Yann Chemin wrote:
> Just wanted to keep exact track of the processing leading to a new layer.
> 1 - would it be feasible to store the whole processing line with
> parameters (i.e. r.something -a input=file_in output-file_out etc...)
> as metadata in the output file of a module ?
G_command_history() already does this, i.e. it appends the result of
G_recreate_command() to the history.
> 2 - would it be interesting to make a scripts/ place inside a mapset
> where scripts would get automatically saved with something like:
> YYYYMMMDDHHHHH_MODULE_NAME.sh or the like?
I'm not sure what you're suggesting here.
GRASS (the libraries and modules) only knows which commands are run;
it doesn't know *how* they are run, e.g. if they are part a script, if
they were typed into the shell, executed by the GUI, etc.
