[GRASS-dev] storing full script as metadata
Yann Chemin
yann.chemin at gmail.com
Mon Jun 9 05:39:03 EDT 2008
2008/6/9 Glynn Clements <glynn at gclements.plus.com>:
> Yann Chemin wrote:
>> Just wanted to keep exact track of the processing leading to a new layer.
>> 1 - would it be feasible to store the whole processing line with
>> parameters (i.e. r.something -a input=file_in output-file_out etc...)
>> as metadata in the output file of a module ?
> G_command_history() already does this, i.e. it appends the result of
> G_recreate_command() to the history.
OK I'll look into it.
>> 2 - would it be interesting to make a scripts/ place inside a mapset
>> where scripts would get automatically saved with something like:
>> YYYYMMMDDHHHHH_MODULE_NAME.sh or the like?
> I'm not sure what you're suggesting here.
> GRASS (the libraries and modules) only knows which commands are run;
> it doesn't know *how* they are run, e.g. if they are part a script, if
> they were typed into the shell, executed by the GUI, etc.
well, since G_recreate_command passed it into the metadata,
I guess already that is good.
I was thinking more of a kind of "command log", but with time-based
separation of commands used in txt files.
Whether they are stored inside a mapset would just be convenient.
thanks
Yann
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
