R: R: [GRASS-dev] WinGRASS Plans
marco.pasetti at alice.it
Thu Jun 12 07:32:19 EDT 2008
Hi Michael,
>maybe try and snatch a copy of the wx-config script
>from a Linux install, then just edit the variables in there
>to fit your MinGW/MSYS setup?
yes! it could be a perfect soultion :)
at the moment I suspended the wxWidgets support task for better times (I read the documentation... too much work and uncertain solutions for the moment...)
If the Linux script will woork ... good! otherwise I will delay the task.
is there anyone outhere that could send me a linux wx-config script please? wxPython version is 2.8.7.1
Many thanks,
Marco
Da: grass-dev-bounces at lists.osgeo.org per conto di Benjamin Ducke
Inviato: gio 12/06/2008 13.24
Cc: grass-dev at lists.osgeo.org
Oggetto: Re: R: [GRASS-dev] WinGRASS Plans
Confirmed: no wx-config script in the Windows bin package :(
However, before you go through the pain of building the whole
thing with MinGW: maybe try and snatch a copy of the wx-config script
Ben
marco.pasetti at alice.it wrote:
> Hi Michael,
> >Maybe this is what you have in mind, but I think that the wx-config is
> only
> >needed for compiling vdigit, not for using it. Also, I'm pretty sure
> that if
> >you install the Windows dev package, it has wx-config.
> I downloaded the Windows dev package, but unfortunately it doesn't
> contain the wx-config file; maybe because it has been built using MS
> Visual C++. I think I'll need to build wxPython from source using MinGW
> to have the wx-config file and, thus, build the new GRASS v.digit.
> I'll let you know.
> Regards,
> Marco
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Benjamin Ducke
Senior Applications Support and Development Officer
Oxford Archaeological Unit Limited
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel: +44 (0)1865 263 800 (switchboard)
Tel: +44 (0)1865 980 758 (direct)
Fax :+44 (0)1865 793 496
benjamin.ducke at oxfordarch.co.uk
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info <http://iso26300.info/> for more information.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080612/daec65df/attachment.html
