R: R: [GRASS-dev] WinGRASS Plans
Benjamin Ducke
benjamin.ducke at oxfordarch.co.uk
Thu Jun 12 08:42:54 EDT 2008
Here you go:
this one taken from 2.8.4.
But I really do not expect any major difference.
Just adjust the version number in the script ...
Ben
marco.pasetti at alice.it wrote:
> Hi Michael,
> >maybe try and snatch a copy of the wx-config script
> >from a Linux install, then just edit the variables in there
> >to fit your MinGW/MSYS setup?
> yes! it could be a perfect soultion :)
> at the moment I suspended the wxWidgets support task for better times (I
> read the documentation... too much work and uncertain solutions for the
> moment...)
> If the Linux script will woork ... good! otherwise I will delay the task.
> is there anyone outhere that could send me a linux wx-config script
> please? wxPython version is 2.8.7.1
> Many thanks,
> Marco
> *Da:* grass-dev-bounces at lists.osgeo.org per conto di Benjamin Ducke
> *Inviato:* gio 12/06/2008 13.24
> *Cc:* grass-dev at lists.osgeo.org
> *Oggetto:* Re: R: [GRASS-dev] WinGRASS Plans
> Confirmed: no wx-config script in the Windows bin package :(
> However, before you go through the pain of building the whole
> thing with MinGW: maybe try and snatch a copy of the wx-config script
> Ben
> > Hi Michael,
> > >Maybe this is what you have in mind, but I think that the wx-config is
> > only
> > >needed for compiling vdigit, not for using it. Also, I'm pretty sure
> > that if
> > >you install the Windows dev package, it has wx-config.
> > I downloaded the Windows dev package, but unfortunately it doesn't
> > contain the wx-config file; maybe because it has been built using MS
> > Visual C++. I think I'll need to build wxPython from source using MinGW
> > to have the wx-config file and, thus, build the new GRASS v.digit.
> > I'll let you know.
> > Regards,
> > Marco
> > grass-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
> Benjamin Ducke
> Senior Applications Support and Development Officer
> Oxford Archaeological Unit Limited
> Janus House
> Osney Mead
> OX2 0ES
> Oxford, U.K.
> Tel: +44 (0)1865 263 800 (switchboard)
> Tel: +44 (0)1865 980 758 (direct)
> Fax :+44 (0)1865 793 496
> Files attached to this email may be in ISO 26300 format (OASIS Open
> Document Format). If you have difficulty opening them, please visit
> http://iso26300.info <http://iso26300.info/> for more information.
Benjamin Ducke
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
#!/bin/sh
# Name: wx-config{.in,}
# Purpose: wx configuration search and query tool {template,}
# Author: Ron <ron at debian.org>
# Modified by:
# Created: 8/9/2004
# RCS-ID: $Id: wx-config.in,v 1.132 2006/12/24 01:20:33 VZ Exp $
# Copyright: (c) 2004 Ron <ron at debian.org>
# Essentially a fresh start this time around, but for maximum
# compatibility basic code was taken from, and heavy reference
# made to, the previously unattributed wx-config from cvs.
# All the usual suspects contributed to the dicussion that led
# to this new work and likewise to the ideas and content in the
# original (which was probably influenced by gtk), among them:
# Robert Roebling, Vadim Zeitlin, Vaclav Slavik, Robin Dunn
# Licence: wxWindows licence
# Extra^2 debug mode, for if things ever get really weird.
[ -z "$WXDEBUG_X" ] || set -x
# On with some basic stuff, like the ability to die gracefully,
# and to tell people what we are about.
# decho _message
# Output a message to stderr.
decho() { echo "$*" 1>&2; }
# usage _exitcode
# Outputs a usage message to stderr and exits with _exitcode.
# Try to keep this to a single page (ie. < 25 lines). We can add
# alternate or interactive help targets if people want more detail.
# Exit codes are now subject to a more strict interpretation.
# wx-config should return 0 upon successful operation, 1 if the
# reqested operation could not be completed successfully, and 2
# if the requested operation is not supported by this version of
# wx-config.
usage()
cat 1>&2 <<EOF
wx-config [--prefix[=DIR]] [--exec-prefix[=DIR]] [--release] [--version-full]
[--list] [--selected-config] [--host=HOST] [--toolkit=TOOLKIT]
[--universal[=yes|no]] [--unicode[=yes|no]] [--debug[=yes|no]]
[--static[=yes|no]] [--version[=VERSION]] [--basename] [--cc]
[--cppflags] [--cflags] [--cxxflags] [--rescomp] [--libs] [--cxx]
[--ld] [--linkdeps] [--utility=UTIL] [LIB ...]
wx-config returns information about the wxWidgets libraries available on
your system. It may be used to retrieve the information required to build
applications using these libraries using --cppflags, --cflags, --cxxflags
and --libs options.
If multiple builds of wxWidgets are available, you can use the options
--prefix, --host, --toolkit, --unicode, --debug, --static, --universal and
--version to select from them. The --selected-config option shows the name
of the current configuration and --list shows available alternatives which
match specified criteria. The --utility option returns the correct version
of UTIL to use with the selected build. The --linkdeps option returns only
static libraries for your makefile link rule dependencies.
Optional LIB arguments (comma or space separated) may be used to specify
the wxWidgets libraries that you wish to use. The magic "std" label may
be used to import all libraries that would be used by default if none were
specified explicitly, e.g. wx-config --libs core,base.
EOF
exit $1
# Unfussy people are the easiest to deal with, get them out of the way now.
[ $# -gt 0 ] || usage 1
# Contentious tools determined by configure.
EGREP="grep -E"
# For the people who know what they want, or think they do:
# Divide the valid arguments into functional groups for later examination,
# then parse all command line arguments completely, deferring action on
# output options until all significant input has been processed and any
# decision about delegation has been taken.
# Note early, that '-' is a complete no-no for use in option names below.
# It totally falls apart as soon as it becomes part of a variable name.
# Use '_' instead, and by the magic of it all just being bits, you'll
# be able to use --my-option or --my_option from the command line at
# your discretion. They are synonymous as user input, but _ALWAYS_ use
# underscores for compound names in the code here, never a dash.
# The list of all options we recognise. If it is not in here, then
# it is not something we want to handle.
# Options that specify a distinct library build.
# Note also that order in this list is significant later on, as this sets
# the precedence with which we will try to gauge the similarity of other
# configs to this one. Options earlier in the list should be more crucial
# to match well than those that follow. Options specified by the user will
# always take precedence and are not subject to any partial ordering here.
wxconfig_schema="host toolkit widgetset chartype debugtype flavour version linkage"
# Options that are expected to generate some output.
wxconfig_output_options="prefix exec_prefix
list
release version version_full
basename
cppflags cflags cxxflags
rescomp
rezflags
libs
linkdeps
cc cxx ld
gl_libs"
# Options that permit the user to supply hints that may affect the output.
# These options all accept arbitrary values, to interpret as they please.
wxconfig_input_options="prefix exec_prefix utility $wxconfig_schema"
# Input options that accept only a yes or no argument.
wxconfig_yesno_options="universal unicode debug static"
# Boolean options that do something or not.
wxconfig_flag_options="$wxconfig_yesno_options selected_config no_rpath inplace"
# Some simple sugar coating to keep things more readable below.
# option_name _string
# Returns NAME if _string is of the form: --NAME[=...]
option_name()
echo "$1" | sed 's/^--//;s/=.*//' | tr '-' '_'
# option_value _string
# Returns FOO if _string is of the form: --option=FOO
option_value()
echo "$1" | sed 's/^[^=]*=//'
# match_field _value _list
# Returns true if _value is a field in _list
match_field()
_match_field_match="$1"
shift
for _match_field_i do
[ "x$_match_field_i" != "x$_match_field_match" ] || return 0
done
false
# remove_field _value _list
# Returns _list minus any field(s) that match _value.
remove_field()
_remf_value="$1"
_remf_list=''
shift
if [ -n "$_remf_value" ]; then
for _remf_item do
[ "x$_remf_item" = "x$_remf_value" ] ||
_remf_list="${_remf_list:+$_remf_list }$_remf_item"
done
echo "$_remf_list"
else
echo $*
fi
# validate_arg _domain _set _name _value
# Boilerplate to validate an argument and initialise a psuedo-hash.
# This one is almost reduction into absurdity, and perhaps makes the
# precise action of the argument parser below just a little more
# obscure, but oh so neat and compact to use for multiple option
# groups. It expands to replace repetitive clauses of the form:
# i="$(option_name $arg)"
# if match_field "$i" $wxconfig_input_options; then
# input_options="${input_options:+$input_options }$i"
# eval "input_option_$i=$(option_value $arg)"
# continue
# fi
# with the one liners you see on the page below.
validate_arg()
if match_field "$3" `eval echo \"\\\$$1_$2_options\"`; then
eval "$2_options=\"\${$2_options:+\$$2_options }$3\""
eval "$2_option_$3=\"$4\""
return
fi
false
# check_yesno_option _ynoption _option _yesval _noval
# This one might be made more generic and/or incorporated into
# validate_arg above at some later stage, but right now we just
# condition any specialist options into a generic one for later
# handling. Once they are sanity checked there is no difference
# in any case.
check_yesno_option()
eval "case \${yesno_option_$1-\${flag_option_$1-unset}} in
unset) ;;
y*|Y*) input_option_$2=\"$3\" ;;
n*|N*) input_option_$2=\"$4\" ;;
decho
decho \" *** Error: Invalid request '--$1=\$yesno_option_$1'\"
decho \" Valid arguments for --$1 are: [ yes, no ]\"
decho
exit 1
esac"
# Now we are ready to find out what the user wants from us.
# With just a little more complexity here we could have shortest
# unique string matching for options, but that is probably overkill
# today, so lets just get the job done.
# The important thing now then is that we simply read all input from
# the user and don't try to act prematurely on partial information.
# --help or an illegal argument are the only shortcuts out of here
# at this point, otherwise, it's time to just shut up and listen for
# a moment.
for arg do
case "$arg" in
--help|-h)
usage
_name=`option_name $arg`
_value=`option_value $arg`
if validate_arg wxconfig input "$_name" "$_value" ||
validate_arg wxconfig yesno "$_name" "$_value"
then
continue
fi
if validate_arg wxconfig flag "$_name" yes ||
validate_arg wxconfig output "$_name" yes
then
continue
fi
# FIXME Surely we can validate the parameters too ...
input_parameters="${input_parameters:+$input_parameters }$arg"
continue
esac
decho " *** Error: Unrecognised option: '$arg'"
decho "Use wx-config --help for information on command line options."
exit 2
done
# validate_arg only checks and decomposes form. Sanity check the yes/no
# options now too and push their respective mask values into place.
check_yesno_option universal widgetset univ
check_yesno_option unicode chartype unicode ansi
check_yesno_option debug debugtype debug release
check_yesno_option static linkage '-static'
# Dump everything we just read in debug mode.
if [ -n "$WXDEBUG" ]; then
decho
decho " input parameters = $input_parameters"
decho " input options = $input_options"
for i in $input_options; do
decho " $i = `eval echo \"\\\$input_option_$i\"`"
done
decho " yes/no options = $yesno_options"
for y in $yesno_options; do
decho " $y = `eval echo \"\\\$yesno_option_$y\"`"
done
decho " flag options = $flag_options"
for f in $flag_options; do
decho " $f = `eval echo \"\\\$flag_option_$f\"`"
done
decho " output options = $output_options"
for o in $output_options; do
decho " $o = `eval echo \"\\\$output_option_$o\"`"
done
fi
# Everything came in as a legal argument then, lets put some of
# the pieces together with a little self knowledge to see what
# we should do next.
# get_mask [ _hash ]
# Construct a config filename mask from a psuedo-hash of component variables.
# The optional argument is the prefix of the hash to use. If not specified
# this will return a mask derived from the command line options that were used.
get_mask()
[ $# -gt 0 ] || set m
eval echo "\${$1_host}\${$1_toolkit}\${$1_widgetset}-\${$1_chartype}-\${$1_debugtype}\${$1_linkage}-\${$1_version}\${$1_flavour}"
# Returns true if this script is for a cross compiled config.
is_cross() { [ "xno" = "xyes" ]; }
# Determine the base directories we require.
prefix=${input_option_prefix-${this_prefix:-/usr}}
exec_prefix=${input_option_exec_prefix-${input_option_prefix-${this_exec_prefix:-${prefix}}}}
wxconfdir="${exec_prefix}/lib/wx/config"
installed_configs=`cd "$wxconfdir" 2> /dev/null && ls | grep -v "^inplace-"`
is_cross && target=""
# Define a pseudo-hash to contain the specification of this wx-config
# instance and its associated library.
this_host="${target:+${target}-}"
this_toolkit="gtk2"
this_widgetset=""
this_chartype="unicode"
this_debugtype="release"
this_flavour=""
this_version="2.8"
this_linkage=`[ "x1" = "x1" ] || echo '-static'`
this_config=`get_mask this`
# Extract the user specification from the options parsed.
m_host=${input_option_host:+"${input_option_host}-?"}
m_host=${m_host:-${input_option_host-$this_host}}
m_toolkit=${input_option_toolkit:-'[^-]+'}
m_widgetset=${input_option_widgetset-'(univ)?'}
m_chartype=${input_option_chartype:-'(unicode|ansi)'}
m_debugtype=${input_option_debugtype:-'(debug|release)'}
m_flavour=${input_option_flavour:+-$input_option_flavour}
m_flavour=${m_flavour:-${input_option_flavour-'(-[^-]+)?'}}
m_version=${input_option_version:-'[0-9]+\.[0-9]+'}
m_linkage=${input_option_linkage-'(-static)?'}
configmask="^`get_mask`$"
# Dump the user specification in debug mode.
decho
decho " prefix = '$prefix'"
decho " exec_prefix = '$exec_prefix'"
decho " wxconfdir = '$wxconfdir'"
decho " m_host = '$m_host'"
decho " m_toolkit = '$m_toolkit'"
decho " m_widgetset = '$m_widgetset'"
decho " m_chartype = '$m_chartype'"
decho " m_debugtype = '$m_debugtype'"
decho " m_flavour = '$m_flavour'"
decho " m_version = '$m_version'"
decho " m_linkage = '$m_linkage'"
decho " configmask = '$configmask'"
decho " this config = '$this_config'"
decho
fi
# From here on, we'll need to be able to figure out a delegation target.
# The rules for delegation are:
# 1. If the specification is so general that it matches the default config
# (ie. this one on a first pass), then the default config will be used
# even if other installed libs would also match the spec.
# 2. If the default config does not match, find a list of all installed
# libraries that do match.
# a. If that list is empty, the specification is incompatible
# with any installed lib. Warn and abort.
# b. If that list contains exactly one candidate. Delegate to
# that candidate.
# c. If the list contains multiple candidates, pass on to step 3.
# 3. Attempt to discriminate among rival candidates by their similarity
# to the default configuration (ie. this one). If we can find a unique
# candidate in this way, delegate to it. If not, present a list of
# options to the user and request that they disambiguate it with one or
# more additional fields.
# To refine the specified pattern, we specialise each unbound field
# using the default value from this config file. If that results in
# no matches, we unbind it again and try the next field. If it still
# results in multiple matches we try binding the next field as well
# until a unique or null result again occurs.
# A more general way to look at this, is the feature specifiers are all
# modifiers of the wx-config you are calling. If you supply none, the
# default for that build configuration will be used. If you supply one
# or more that the default build cannot satisfy, it will try to find the
# config most like itself with the desired feature(s) enabled.
# The features configured into the first wx-config called will be taken
# as implicitly specified if it is necessary to disambiguate likely
# candidates from the information that was explicitly provided.
# But first, more sugar to keep what follows clear and legible.
# find_eligible_delegates _mask
# Outputs all the config files installed which match the
# (extended regex) _mask passed as an argument.
find_eligible_delegates() { echo "$installed_configs" | $EGREP "$1" 2> /dev/null; }
# user_mask_fits _config
# Returns true if the string _config satisfies the user specified mask.
user_mask_fits() { echo "$1" | $EGREP "$configmask" > /dev/null 2>&1; }
# count_fields _word
# Returns the number of IFS split fields in _word
count_fields() { return $#; }
# count_delegates _mask
# Return the number of eligible config files that match _mask
count_delegates() { count_fields `find_eligible_delegates $1`; }
# is_set _variablename
# Returns true if $_variablename is initialised.
is_set() { [ "x`eval echo \"\\\${$1-unset}\"`" != "xunset" ]; }
# not _cmd _args...
# true iff _cmd is false
not() { if "$@"; then false; else true; fi; }
# do_find_best_delegate _unbound-options
# The real worker part of find_best_delegate below. Recurses though all
# unbound options binding them one at a time to the default derived from
# this file until a unique match is made or no alternatives remain that
# may be sensibly guessed at. It will preferentially bind the unspecified
# options in the order they are listed in wxconfig_schema. Using this
# partial ordering it should find the first match with the most significant
# similarity to this file that unambiguously meets the user specification.
# If such a match exists it will be output to stdout.
# Be careful if you modify this function. If the pruning logic is rendered
# inoperative it will simply recurse over every permutation in the search
# space, which may still appear to work, but add a couple more options (or
# explicitly specify a few less) and you may not live long enough to learn
# the result. WXDEBUG=findprogress is your friend here, it will show you
# how many nodes get searched before a result. If you start seeing
# increases in that number for the same input, check your work.
# Raising the number of discriminating options from 6 to 8 raised the worst
# case time for this to run (without pruning) from 3 to nearly 15 seconds
# and its downhill fast from here if we have to ride that boat.
# Early pruning still gets that down to under half a second (up from about
# .25), so we have some breathing space yet before a different search method
# will be called for, but lets not squander it.
do_find_best_delegate()
if [ "x$WXDEBUG" = "xverbose" ]; then
_fbd_indent="${_fbd_indent}. "
decho " $_fbd_indent---> unbound options: $*"
fi
for i do
decho " ${_fbd_indent}binding '$i' with '`remove_field $i $*`' still free"
[ -z "$_pruned" ] || decho " ${_fbd_indent} --- pruned: $_pruned ---"
fi
if (
eval m_$i=\$this_$i
_mask="^`get_mask`$"
decho " ${_fbd_indent} checking: $_mask"
count_delegates "$_mask"
decho " $_fbd_indent $? eligible delegates"
for d in `find_eligible_delegates "$_mask"`; do
decho " ${_fbd_indent} $d"
done
fi
_still_eligible=$?
if [ $_still_eligible -eq 1 ]; then
echo `find_eligible_delegates "$_mask"`
return
fi
[ "x$WXDEBUG" != "xfindprogress" ] || printf "." 1>&2
[ $_still_eligible -gt 1 ] && [ $# -gt 1 ] &&
do_find_best_delegate `remove_field $i $*`
then
return
elif [ $# -gt 1 ]; then
decho " ${_fbd_indent}pruning: $i"
_pruned="${_pruned:+$_pruned }$i"
fi
set `remove_field $i $*`
fi
done
false
# find_best_delegate
# A simple wrapper around do_find_best_delegate that first determines
# the unbound options (ie. the ones that the user did not explicitly
# declare a preference for on the command line)
for _fbdi in $wxconfig_schema; do
is_set input_option_$_fbdi ||
_unbound_options="${_unbound_options:+$_unbound_options }$_fbdi"
done
do_find_best_delegate $_unbound_options
# Legacy wx-config helpers.
# get_legacy_mask
# Returns a mask in the format used by wx2.4.
get_legacy_mask()
eval [ "x\${$1_chartype}" != "xunicode" ] || _unicode_flag=u
eval [ "x\${$1_debugtype}" != "xdebug" ] || _debug_flag=d
eval echo "wx\${$1_toolkit}${_unicode_flag}${_debug_flag}-\${$1_version}\${$1_host}-config"
# find_legacy_configs
# Returns a list of configs installed by wx2.4 releases.
find_legacy_configs()
cd "$prefix/bin" &&
ls wx*-2.4-config | grep -v ^wxbase
ls wx*-2.4-config | grep ^wxbase
) 2> /dev/null
# find_best_legacy_config
# Returns the best legacy config for a given specification.
# This assumes no matching new style config has been found.
find_best_legacy_config()
_legacy_configs=`find_legacy_configs`
if [ -n "$_legacy_configs" ]; then
_legacy_mask=`get_legacy_mask`
for d in $_legacy_configs; do
if echo $d | $EGREP $_legacy_mask > /dev/null 2>&1 ; then
echo "$d"
return
fi
done
fi
false
# The only action we can perform authoritatively prior to delegation
# is to list all the possible delegates.
config_spec="$0 $*"
[ -z "$WXDEBUG" ] || config_spec=$configmask
# Next chance for another satisfied customer then
# If we want to get really polished here we can do plural checking,
# but we should probably leave that until the day we gettextise it.
if [ -n "$output_option_list" ]; then
_remains_in_prefix=$installed_configs
_delegates=`find_eligible_delegates $configmask`
_best_delegate=`find_best_delegate`
decho
decho " all = $_remains_in_prefix"
decho " matching = $_delegates"
decho " best = $_best_delegate"
decho " this = $this_config"
fi
for d in $_delegates; do
_remains_in_prefix=`remove_field $d $_remains_in_prefix`
done
echo
echo " Default config is $this_config"
echo
if user_mask_fits "$this_config" ; then
echo " Default config ${this_exec_prefix+in $this_exec_prefix }will be used for output"
if match_field "$this_config" $_delegates ; then
_delegates=`remove_field $this_config $_delegates`
else
echo " though it is not installed in: $prefix"
if [ -n "$_best_delegate" ] && [ "x$_best_delegate" != "x$this_config" ]; then
echo
echo " Best alternate in $prefix:"
echo " $_best_delegate"
fi
fi
elif [ -n "$_best_delegate" ]; then
echo " Specification best match: $_best_delegate"
elif [ -z "$_delegates" ]; then
_last_chance=`find_best_legacy_config`
if [ -n "$_last_chance" ]; then
echo " Specification matches legacy config: $_last_chance"
else
cat <<-EOF
No config found to match: $config_spec
in $wxconfdir
Please install the desired library build, or specify a different
prefix where it may be found. If the library is not installed
you may call its wx-config directly by specifying its full path.
EOF
fi
else
echo " Specification was ambiguous. Use additional feature options"
echo " to choose between alternate matches."
fi
_delegates=`remove_field "$_best_delegate" $_delegates`
if [ -n "$_delegates" ]; then
echo
echo " Alternate matches:"
echo " $d"
done
fi
if [ -n "$_remains_in_prefix" ]; then
echo
echo " Also available in $prefix:"
for d in $_remains_in_prefix; do
echo " $d"
done
fi
echo
echo " Legacy configs available in $prefix:"
echo " $d" | sed 's/-config$//'
done
fi
echo
exit
fi
# ... so if that wasn't what they wanted, then we need to know for
# certain, can this config satisfy the user specification?
if not user_mask_fits "$this_config" ; then
# No? Then lets see if it knows anybody who can.
# But first, just be sure someone hasn't typo'd us into a loop.
# In present day wx, correct delegation should never need more
# than one hop so this is trivial to detect.
if [ -n "$WXCONFIG_DELEGATED" ]; then
decho
decho " *** Error: Bad config delegation"
decho
decho " to: $0"
decho " ($this_config) cannot satisfy:"
decho " $config_spec"
decho " Someone has been terribly careless."
decho
exit 1
fi
count_delegates "$configmask"
_numdelegates=$?
decho " must delegate to an alternate config"
decho " potential delegates ($_numdelegates):"
for i in `find_eligible_delegates "$configmask"`; do
decho " $i"
done
fi
if [ $_numdelegates -eq 0 ]; then
for arg do
case "$arg" in
--prefix*|--exec-prefix*| \
--version|--release|--basename| \
--static|--libs|--gl_libs| \
--cppflags|--cflags|--cxxflags| \
--cc|--cxx|--ld| \
--rezflags|--inplace)
_legacy_args="$_legacy_args $arg"
--static|--static=y*|--static=Y*)
_legacy_args="$_legacy_args --static"
esac
done
decho " found a suitable legacy delegate: $_last_chance"
decho "--> $prefix/bin/$_last_chance $_legacy_args"
fi
export WXCONFIG_DELEGATED=yes
exit
else
cat 1>&2 <<-EOF
Warning: No config found to match: $config_spec
in $wxconfdir
If you require this configuration, please install the desired
library build. If this is part of an automated configuration
test and no other errors occur, you may safely ignore it.
You may use wx-config --list to see all configs available in
the default prefix.
EOF
# PIPEDREAM: from here we are actually just a teensy step
# from simply building the missing config for the user
# on the fly if this is an in tree wx-config.
exit 1
fi
fi
if [ $_numdelegates -gt 1 ]; then
[ -z "$WXDEBUG" ] || decho " must prune the list of eligible delegates"
if [ -n "$best_delegate" ]; then
decho " found a suitable delegate: $best_delegate"
decho "--> $wxconfdir/$best_delegate $*"
fi
exit
fi
decho
decho " *** Error: Specification is ambiguous"
decho " as $config_spec"
decho " Use additional feature options to choose between:"
decho " $i"
done
decho
exit 1
fi
decho " using the only suitable delegate"
decho "--> $wxconfdir/`find_eligible_delegates $configmask` $*"
fi
exit
fi
# If we are still here, then from now on we are responsible for
# all the user's needs. Time to rustle up some output for them.
[ -z "$WXDEBUG" ] || decho " using this config"
# If the user supplied a prefix, and the in tree config did not
# delegate out to anything in that prefix, then reset the build
# tree prefix to provide the correct output for using this
# uninstalled wx build. Or put more simply:
prefix=${this_prefix-$prefix}
exec_prefix=${this_exec_prefix-$exec_prefix}
includedir="${prefix}/include"
libdir="${exec_prefix}/lib"
bindir="${exec_prefix}/bin"
# Trivial queries we can answer now.
[ -z "$output_option_prefix" ] || echo $prefix
[ -z "$output_option_exec_prefix" ] || echo $exec_prefix
[ -z "$output_option_release" ] || echo "2.8"
[ -z "$output_option_version" ] || echo "2.8.4"
[ -z "$output_option_version_full" ] || echo "2.8.4.0"
[ -z "$output_option_basename" ] || echo "wx_gtk2u"
[ -z "$output_option_cc" ] || echo "gcc"
[ -z "$output_option_cxx" ] || echo "g++"
[ -z "$output_option_ld" ] || echo "g++ -shared -fPIC -o"
[ -z "$flag_option_selected_config" ] || echo "$this_config"
# --rezflags is deprecated and disabled (2005/11/29)
if [ -n "$output_option_rezflags" ]; then
echo "@true"
decho "Warning: --rezflags, along with Mac OS classic resource building" \
"is deprecated. You should remove this from your Makefile and" \
"build .app bundles instead."
fi
# The rest are going to need a little more work.
is_monolithic() { [ "x0" = "x1" ]; }
is_static() { [ -n "$this_linkage" ]; }
is_installed() { [ -z "$this_prefix" ]; }
# Is the user after a support utility?
# If this is a cross build, we need to find and return a suitable
# native utility for the job, so we search:
# 1. local build dir (for native uninstalled builds only).
# 2. (optional) user supplied prefix.
# 3. configured install prefix.
# 4. environment $PATH.
# and if such a thing still cannot be found, exit signalling an error.
if [ -n "$input_option_utility" ]; then
# This is dumb, in tree binaries should be in a standard location
# like the libs, but work with what we've got for now.
is_cross || _util="$exec_prefix/utils/$input_option_utility/$input_option_utility"
if not is_installed && [ -x "$_util" ]; then
is_static || _preload="eval LD_LIBRARY_PATH=$exec_prefix/lib"
echo $_preload $_util
exit
fi
IFS=':'
_user_prefix=${input_option_exec_prefix:-$input_option_prefix}
for _util in "${input_option_utility}-2.8" \
"${input_option_utility}"
do
for p in ${_user_prefix:+$_user_prefix/bin} $bindir $PATH; do
[ -z "$WXDEBUG" ] || decho " checking for: '$p/$_util'"
if [ -x "$p/$_util" ]; then
echo "$p/$_util"
exit
fi
done
done
exit 1
fi
# Still here? Then get the options together for building an app.
# Additional configuration for individual library components.
ldflags_gl=""
ldlibs_base="-lwxregexu-2.8 -lz -ldl -pthread -lgstreamer-0.10 -lgmodule-2.0 -ldl -lxml2 -lgconf-2 -lORBit-2 -lgthread-2.0 -lrt -lgobject-2.0 -lglib-2.0 -lgstinterfaces-0.10 -lm"
ldlibs_core="-pthread -lgtk-x11-2.0 -lgdk-x11-2.0 -latk-1.0 -lgdk_pixbuf-2.0 -lm -lfontconfig -lXext -lXrender -lXinerama -lXi -lXrandr -lXcursor -lXcomposite -lXdamage -lpango-1.0 -lX11 -lXfixes -lgobject-2.0 -lgmodule-2.0 -ldl -lgthread-2.0 -lrt -lglib-2.0 -lXinerama -lSM -lpng -lz -ljpeg -ltiff"
ldlibs_gl="-lGL -lGLU"
ldlibs_html=""
ldlibs_xml=" -lexpat"
ldlibs_odbc=""
ldlibs_adv=""
# lib_flags_for _liblist
# This function returns a list of flags suitable to return with the
# output of --libs for all of the libraries in _liblist. You can
# add support for a new library by adding an entry for it in the
# psuedo-hashes above if it requires additional linker options.
lib_flags_for()
[ -z "$WXDEBUG" ] || decho " fetching lib flags for: '$*'"
_all_ldflags=''
_all_libs=''
_wxlibs=''
is_cross && _target="-${target}"
for lib do
# We evidently can't trust people not to duplicate things in
# configure, or to keep them in any sort of sane order overall,
# so only add unique new fields here even if it takes us a while.
# In the case of libs, we bubble any duplicates to the end,
# because if multiple libs require it, static linking at least
# will require it to come after all of them. So long as local
# order is ok in configure then we should always be able to
# massage a correct result here like this.
# FIXME: ldlibs_core is totally bogus. Fix the duplication
# there independently of this. This covers for it, but we
# want to do this anyway because some libs may share common
# deps without a common ancestor in wx. This is not a licence
# for sloppy work elsewhere though and @GUI_TK_LIBRARY should
# be fixed.
for f in `eval echo \"\\\$ldflags_$lib\"`; do
match_field "$f" $_all_ldflags || _all_ldflags="$_all_ldflags $f"
done
if match_field "$lib" xml net base ; then
_libname="wx_baseu"
else
_libname="wx_gtk2u"
fi
[ $lib = base ] || _libname="${_libname}_$lib"
_libname="${_libname}-2.8$_target"
if is_static; then
_wxlibs="$_wxlibs ${libdir}/lib${_libname}.a"
for f in `eval echo \"\\\$ldlibs_$lib\"`; do
# Only propagate duplicate -libraries to their latest
# possible position. Do not eliminate any other
# duplicates that might occur. They should be fixed
# in configure long before they get here.
# This started as a workaround for Mac -framework,
# but it seems like a better policy in general, which
# will let the more heinous bugs in configure shake out.
# We should maybe filter *.a here too, but not unless
# we have to.
case "$f" in
-l*) _all_libs="`remove_field $f $_all_libs` $f" ;;
*) _all_libs="$_all_libs $f" ;;
esac
done
else
_wxlibs="$_wxlibs -l${_libname}"
fi
done
decho " retrieved: ldflags = $_all_ldflags"
decho " wxlibs = $_wxlibs"
decho " alllibs = $_all_libs"
fi
echo $_all_ldflags $_wxlibs $_all_libs
# this is the strict subset of the above function which returns only the
# (static) libraries themselves: this is used for linkdeps output which should
# output the list of libraries the main program should depend on
# of course, this duplication is bad but I'll leave to somebody else the care
# of refactoring this as I don't see any way to do it - VZ.
# This (and the other cruft to support it) should be removed with
# reference to the FIXME above when configure stops piping us a slurry
# of options that need to be decomposed again for most practical uses - RL.
link_deps_for()
_wxlibs=''
for lib do
_libname="wx_baseu"
else
_libname="wx_gtk2u"
fi
done
echo $_wxlibs
# Sanity check the list of libs the user provided us, if any.
wx_libs=`echo "$input_parameters" | tr ',' ' '`
[ -z "$WXDEBUG" ] || decho " user supplied libs: '$wx_libs'"
if is_monolithic; then
# Core libs are already built into the blob.
for i in std aui xrc qa html adv core xml net base; do
wx_libs=`remove_field $i $wx_libs`
done
wx_libs=" `lib_flags_for $wx_libs`"
# We still need the core lib deps for a static build though
if is_static; then
link_deps="${libdir}/libwx_gtk2u-2.8.a"
wx_libs="$wx_libs $link_deps $ldlibs_core $ldlibs_base"
else
wx_libs="$wx_libs -lwx_gtk2u-2.8"
fi
using_gui=yes
else # MONOLITHIC = 0
# Import everything by default, expand std if specified, or add base if omitted.
if [ -z "$wx_libs" ]; then
wx_libs="aui xrc qa html adv core xml net base"
elif match_field std $wx_libs; then
# Bubble any libs that were already specified to the end
# of the list and ensure static linking order is retained.
wx_libs=`remove_field std $wx_libs`
for i in aui xrc qa html adv core xml net base; do
wx_libs="`remove_field $i $wx_libs` $i"
done
elif not match_field base $wx_libs ; then
wx_libs="$wx_libs base"
fi
using_gui=no
for i in $wx_libs ; do
if match_field "$i" aui xrc qa html adv core ; then
_guildflags=""
using_gui=yes
break
fi
match_field "$i" xml net base || using_gui=yes
done
if is_static; then
link_deps=`link_deps_for $wx_libs`
fi
wx_libs="$_guildflags `lib_flags_for $wx_libs`"
fi
decho
decho " using libs: '$wx_libs'"
decho " using_gui = $using_gui"
decho
fi
# Endgame. Nothing left to discover now.
[ "$using_gui" = "yes" ] || _gui_cppflags="-DwxUSE_GUI=0"
if is_installed; then
_include_cppflags="-I${includedir}/wx-2.8"
else
_include_cppflags="-I${includedir} -I${prefix}/contrib/include"
fi
_cppflags=`echo "-I${libdir}/wx/include/gtk2-unicode-release-2.8" $_include_cppflags "-D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D__WXGTK__" $_gui_cppflags`
# now without further ado, we can answer these too.
[ -z "$output_option_cppflags" ] || echo $_cppflags
[ -z "$output_option_cflags" ] || echo $_cppflags "-pthread"
[ -z "$output_option_cxxflags" ] || echo $_cppflags "-pthread"
[ -z "$output_option_gl_libs" ] || echo `lib_flags_for gl`
[ -z "$output_option_linkdeps" ] || echo $link_deps
if [ -n "$output_option_libs" ]; then
is_cross &&
[ "x$libdir" = "x/usr/${target}/lib" ] ||
[ "x$libdir" = "x/usr/lib" ] ||
_ldflags="-L$libdir"
is_installed || [ -n "$flag_option_no_rpath" ] || _rpath="-Wl,-rpath,$libdir"
echo $_ldflags "-pthread " $_rpath $wx_libs ""
fi
# xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
# Beyond here reside only machine or tool specific workarounds
# that require knowlege not obtainable prior to this comment.
# Please. Avoid addding things here, wx-config should avoid
# hard coding tool specific details. Do not use things here
# as an example of other things that should be here, These
# shouldn't be here either. This is a place of last resort
# for interim workarounds. I can but stress as strongly as
# the censor will allow, there are only bad examples of things
# that belong at this level of abstraction to follow. It is
# a limbo for glitches awaiting the Next Design Repair. Ok.
# With that firmly in mind, our debut dilemma is:
# Resource compilers. An elusive term that covers some pretty
# dissimilar concepts on various platforms. The good news is,
# each platform has only one definition of 'resource', compiled
# or not, and so we can abstract that neatly to return a platform
# specific invocation of the appropriate tool. The bad news is,
# windres (at least) requires knowledge of the wx header files
# location(s) that cannot be predicted reliably before the call to
# wx-config is made. Currently for all known resource compilers,
# we can simply return a command and some salient configuration
# options in response to a request for --rescomp. So here we
# top up the options for any tools that may require information
# that was only just determined in the last few machine cycles,
# then output the necessary incantation for the platform.
# Most things should already be constant by the time configure
# has run. Do not add anything here that is already known there.
if [ -n "$output_option_rescomp" ]; then
case "" in
*windres|wrc)
# Note that with late model windres, we could just insert
# _include_cppflags here, but use the old notation for now
# as it is more universally accepted.
echo " --include-dir" \
"${includedir}/wx-2.8" \
else
echo " --include-dir ${includedir}" \
"--include-dir ${prefix}/contrib/include" \
fi
# neither rez not emxbind have any specific needs from
# us, so just output what was determined by configure.
echo
esac
fi
# And so that's it, we're done. Have a nice build.
exit 0
