[GRASS-dev] proper v.parallel behavior on strange input
Росен Матев r.matev at gmail.com
Mon Jun 16 17:31:42 EDT 2008
Hi again,
This time I'm challenging you with another strange line. What should
v.parallel output, with options dist=7, side=left and straight corners
(round corners), given that input? I won't give you current behavior
of v.parallel2 (or other suggestions), cause I don't want to influence
on your opinion.
Rosen
