[GRASS-dev] proper v.parallel behavior on strange input
Росен Матев r.matev at gmail.com
Mon Jun 16 17:37:37 EDT 2008
And here is the input
Absently,
Rosen
On Tue, Jun 17, 2008 at 12:31 AM, Росен Матев <r.matev at gmail.com> wrote:
> Hi again,
> This time I'm challenging you with another strange line. What should
> v.parallel output, with options dist=7, side=left and straight corners
> (round corners), given that input? I won't give you current behavior
> of v.parallel2 (or other suggestions), cause I don't want to influence
> on your opinion.
> Rosen
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080617/6b5c3c11/par_line.png
