[GRASS-dev] [GRASS GIS] #188: MySQL driver: create table command cut
    trac at osgeo.org
    Mon Jun 16 17:49:12 EDT 2008
 Reporter:  neteler  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:  6.4.0
Component:  default  |     Version:  svn-trunk
 Keywords:           |
 While copying all OSGeo NC data set vector maps from PERMANENT into a
 "mysql" mapset, I got the following problem:
 for i in `g.mlist type=vect map=PERMANENT` ; do
   echo "------ $i:"
   g.copy vect=$i,my$i
 done
 precip_30ynormals_3d:
 Copy vector <precip_30ynormals_3d at PERMANENT> to current mapset as
 <myprecip_30ynormals_3d>
 DBMI-MySQL driver error:
 Cannot create table:
 CREATE TABLE myprecip_30ynormals_3d ( cat INTEGER, station DOUBLE, lat
 DOUBLE, long DOUBLE, elev DOUBLE, jan DOUBLE, feb DOUBLE, mar DOUBLE, apr
 DOUBLE, may DOUBLE, jun DOUBLE, jul DOUBLE, aug DOUBLE, sep DOUBLE, oct
 DOUBLE, nov DOUBLE, dec DOUBLE, annual DOUBLE )
 You have an error in your SQL syntax; check the manual that corresponds to
 your MySQL server version for the right syntax to use near 'long DOUBLE,
 elev DOUBLE, jan DOUBLE, feb DOUBLE, mar DOUBLE, apr DOUBLE, may DO' at
 line 1
 WARNING: Cannot create new table
 Apparently the string is cut somewhere. I checked
 db/drivers/mysql/create_table.c but could not find any reason.
 Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/188>
