[GRASS-dev] Re: [GRASS GIS] #163: g.transform no longer calculating error for 2nd order transformation
GRASS GIS trac at osgeo.org
Tue Jun 17 06:44:31 EDT 2008
  Reporter:  cmbarton  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  major     |   Milestone:  6.3.1
 Component:  default   |     Version:  svn-develbranch6
Resolution:            |    Keywords:  g.transform georectify
Comment (by martinl):
 Replying to [ticket:163 cmbarton]:
 > Sometime recently, g.transform stopped calculating forward and backward
 error for 2nd order transformations. It simply returns 0's. 1st order
 transformations still work fine AFAICT.
 The 2nd order transformations requires at least 6 GCPs. Your input POINTS
 file contains 6 points. Then forward/reverse error is 0.0's.
 Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/163#comment:1>
