[GRASS-dev] Re: [GRASS GIS] #163: g.transform no longer calculating
error for 2nd order transformation
Michael Barton
michael.barton at asu.edu
Tue Jun 17 08:02:22 EDT 2008
Yes. This has 6 points like it is supposed to. But the transformation
doesn't work. Doesn't work with more than 6 either.
Michael
On 6/17/08 3:44 AM, "GRASS GIS" <trac at osgeo.org> wrote:
> #163: g.transform no longer calculating error for 2nd order transformation
> Reporter: cmbarton | Owner: grass-dev at lists.osgeo.org
> Type: defect | Status: new
> Priority: major | Milestone: 6.3.1
> Component: default | Version: svn-develbranch6
> Resolution: | Keywords: g.transform georectify
> Comment (by martinl):
> Replying to [ticket:163 cmbarton]:
>> Sometime recently, g.transform stopped calculating forward and backward
> error for 2nd order transformations. It simply returns 0's. 1st order
> transformations still work fine AFAICT.
> The 2nd order transformations requires at least 6 GCPs. Your input POINTS
> file contains 6 points. Then forward/reverse error is 0.0's.
> Martin
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
