[GRASS-dev] Re: [GRASS GIS] #189: WinGRASS installer can not find NC sampledata
GRASS GIS trac at osgeo.org
Wed Jun 18 05:58:46 EDT 2008
  Reporter:  mloskot       |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  major         |   Milestone:
 Component:  Installation  |     Version:  6.3.0
Resolution:                |    Keywords:  MS Windows, sample data north carolina
Comment (by marcopx):
 Replying to [comment:5 neteler]:
 > (Un)related to this: if you don't select any dataset to be installed it
 starts with broken .gisrc6 file apparently (not sure how this file works
 under Windows, at least the startup is blocked with a related message).
 > Markus
 No, on Windows it doesn't happen, because the installer creates a .gisrc6
 file that "points" to the demolocation (installed in $DOCUMENTS/GIS
 DataBase, as the others sample datasets, if selected)
 Marco
Ticket URL: <http://trac.osgeo.org/grass/ticket/189#comment:6>
