[GRASS-dev] Re: [GRASS GIS] #189: WinGRASS installer can not find
NC sampledata
trac at osgeo.org
Wed Jun 18 06:13:31 EDT 2008
#189: WinGRASS installer can not find NC sampledata
Reporter: mloskot | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone:
Component: Installation | Version: 6.3.0
Resolution: | Keywords: MS Windows, sample data north carolina
Comment (by marcopx):
Replying to [comment:6 marcopx]:
> Replying to [comment:5 neteler]:
> > (Un)related to this: if you don't select any dataset to be installed
it starts with broken .gisrc6 file apparently (not sure how this file
works under Windows, at least the startup is blocked with a related
message).
> > Markus
> No, on Windows it doesn't happen, because the installer creates a
.gisrc6 file that "points" to the demolocation (installed in
$DOCUMENTS/GIS DataBase, as the others sample datasets, if selected)
> Marco
Sorry, misunderstanding: I read .grassrc6 instead of .gisrc6; AFAIK,
.gisrc6 is not used in WinGRASS,
Marco
Ticket URL: <http://trac.osgeo.org/grass/ticket/189#comment:8>
