[GRASS-dev] proper v.parallel behavior on strange input
Росен Матев r.matev at gmail.com
Wed Jun 18 15:24:09 EDT 2008
I propose that I cancel development of "clean_parallel()" (the
function which removes loops), cause its proper behavior is not
determined now (and it might not be possible to determine it).
Instead, I'll start making function which generates "type B" lines,
which will be more useful in buffer generation. What do you think
about it?
Rosen
