[GRASS-dev] Re: [GRASS-user] low radiance values after i.atcor
and i.topo.corr
Markus Neteler
neteler at osgeo.org
Mon Jun 23 15:23:14 EDT 2008
On Mon, Jun 23, 2008 at 7:04 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
> > >> > And i.smap is gibberish; e.g. write_img() calls G_is_c_null_value() on
> > >> > "char"s, so that module probably hasn't worked since 4.x.
> > >> i.smap works, I have tested it recently and also others use it regularly.
> > > Oh, it may produce output, but not necessarily correct output.
> > > Specifically, write_img() does:
> > > if(G_is_c_null_value((CELL *)&img[row][col]))
> > > G_set_c_null_value(&files->cellbuf[col], 1);
> > > But "img" is a "unsigned char **", i.e. a 2D array of bytes. The test
> > > will only succeed if the array contains the sequence 00,00,00,80 (for
> > > little-endian systems) or 80,00,00,00 (big-endian systems). I suspect
> > > that the test was originally against zero, but it was incorrectly
> > > changed when null support was added.
> > > If that's the case, the net result will be that it writes garbage
> > > where it should be writing nulls, and occasionally writes nulls where
> > > it shouldn't.
> > That sounds quite ugly. But from looking at the code: is a major
> > rewrite needed to fix that? Since we "just" write out classes?
> For now, I have just disabled the test:
> if(0 && img[row][col] == 0)
> G_set_c_null_value(&files->outbuf[col], 1);
> so it will never write out nulls. Previously, these would have been
> relatively uncommon anyhow.
> I initially suspected that the test should have been against zero, but
> in retrospect, it may have been completely absent (i.e. the change was
> made on the assumption that zero represented null when it actually
> represented zero).
> Ultimatly, you would need to look at a pre-5.x version (or to actually
> understand the code) in order to determine what it should be doing.
here is the 4.3 code:
grass4.3src/src/imagery/i.smap/cmd/shapiro/write_img.c
#include "imagery.h"
#include "files.h"
#include "parms.h"
write_img (img, ncols, nrows, S, parms, files)
unsigned char **img;
struct SigSet *S; /* class parameters */
struct parms *parms; /* parms: command line parameters */
struct files *files; /* files: contains file to output */
int row, col;
int class;
if (!parms->quiet) fprintf (stderr, "Writing %s ... ", parms->output_map);
for (row = 0; row < nrows; row++)
if (!parms->quiet) G_percent (row, nrows, 2);
for (col = 0; col < ncols; col++)
class = (int)img[row][col];
files->cellbuf[col] = (CELL)S->ClassSig[class].classnum;
G_put_map_row (files->output_fd, files->cellbuf);
Markus
