[GRASS-dev] Re: [GRASS-user] low radiance values after i.atcor
and i.topo.corr
Glynn Clements
glynn at gclements.plus.com
Mon Jun 23 17:54:36 EDT 2008
Markus Neteler wrote:
> > I initially suspected that the test should have been against zero, but
> > in retrospect, it may have been completely absent (i.e. the change was
> > made on the assumption that zero represented null when it actually
> > represented zero).
> > Ultimatly, you would need to look at a pre-5.x version (or to actually
> > understand the code) in order to determine what it should be doing.
> here is the 4.3 code:
> grass4.3src/src/imagery/i.smap/cmd/shapiro/write_img.c
> for (col = 0; col < ncols; col++)
> class = (int)img[row][col];
> files->cellbuf[col] = (CELL)S->ClassSig[class].classnum;
Yep; the test should never have been added (zero doesn't signify
null), so I have removed it.
