[GRASS-dev] Re: r.walk and r.drain improvements
Dylan Beaudette
dylan.beaudette at gmail.com
Tue Jun 24 10:23:16 EDT 2008
On Tue, Jun 24, 2008 at 4:22 AM, Colin Nielsen <colin.nielsen at gmail.com> wrote:
> Hi Dylan,
> Excellently documented example by the way.
Thanks!
> The path is probably quite similar but the point is that there is
> currently no way to ensure that the r.drain path conforms to the same
> path as the optimal path of cost accumulation (calculated by r.walk or
> r.cost).
I see. I didn't quite understand your original post apparently. I
would be happy to help try out any modifications to r.walk/r.drain.
> Specifically I can't comment on your example yet because I haven't
> completed my changes to r.drain. When I do (assuming I remember) I
> will be glad to re-run your analysis to see what difference is
> present.
> -Colin
Sounds good.
Cheers,
Dylan
>>Interesting post Colin. Can you comment on the differences between
>>r.drain and r.walk in this example [1], in light of your findings?
>>1. http://casoilresource.lawr.ucdavis.edu/drupal/node/544
>>Cheers,
>>Dylan
>>_______________________________________________
>>grass-dev mailing list
>>grass-dev at ...
>>http://lists.osgeo.org/mailman/listinfo/grass-dev
> grass-dev at lists.osgeo.org
