[GRASS-dev] Re: g.mlist
Huidae Cho grass4u at gmail.com
Sat Jun 28 14:15:47 EDT 2008
On Sat, Jun 28, 2008 at 08:31:32AM -0700, Hamish wrote:
> Hi,
> re. "sep= changed to separator= while keeping backward compatibility"
> two points-
> ) I think it should be changed to fs= to match the rest of GRASS.
> ) backwards compatibility with grass7 (trunk) is nice to do, but it is not at all guaranteed. ie we can break things as we like. it's the dev-branch6 where backwards compatibility must be strictly followed.
Yes, fs= looks better than separator=.  If there are no objections to
breaking this backward compatibility, I'll change it again to fs=.
> cheers,
> Hamish
> ps- glad to see the speedups! Now we only have to rewrite that module in C.. parsing the g.list output will always be a little fragile/slow, and a goal of grass7 is to do without helping unix tools so there are fewer problems on the MS Windows port.
I agree with you that something needs to be done for grass7.  Ideally,
g.mlist/g.mremove should be removed by extending g.list/g.remove.
Probably, grass7 will require one more library by default that handles
regular expressions (e.g., POSIX regex, pcre).  More generally, we could
implement regex expansion into standard options (too much?).
Huidae
