[GRASS-dev] Re: g.mlist
Huidae Cho
grass4u at gmail.com
Sat Jun 28 14:28:27 EDT 2008
On Sat, Jun 28, 2008 at 01:15:47PM -0500, Huidae Cho wrote:
> On Sat, Jun 28, 2008 at 08:31:32AM -0700, Hamish wrote:
> > Hi,
> > re. "sep= changed to separator= while keeping backward compatibility"
> > two points-
> > ) I think it should be changed to fs= to match the rest of GRASS.
> > ) backwards compatibility with grass7 (trunk) is nice to do, but it is not at all guaranteed. ie we can break things as we like. it's the dev-branch6 where backwards compatibility must be strictly followed.
> Hi,
> Yes, fs= looks better than separator=. If there are no objections to
> breaking this backward compatibility, I'll change it again to fs=.
> > cheers,
> > Hamish
> > ps- glad to see the speedups! Now we only have to rewrite that module in C.. parsing the g.list output will always be a little fragile/slow, and a goal of grass7 is to do without helping unix tools so there are fewer problems on the MS Windows port.
BTW, does this mean we cannot take advantage of backticks (e.g.,
input=`g.mlist pat=time*`) any more? Then is the only option regex
support for standard options? Or is it just g.mlist/g.mremove?
> I agree with you that something needs to be done for grass7. Ideally,
> g.mlist/g.mremove should be removed by extending g.list/g.remove.
> Probably, grass7 will require one more library by default that handles
> regular expressions (e.g., POSIX regex, pcre). More generally, we could
> implement regex expansion into standard options (too much?).
> Huidae
