[GRASS-dev] Re: SoC Report: v.buffer/v.parallel reimplementation
Hamish
hamish_b at yahoo.com
Sun Jun 29 20:38:39 EDT 2008
Maybe a not very meaningful test, but how does it do with the previously problematic "ditches" vector from Maciek?
http://intevation.de/rt/webrt?serial_num=2765
I recall that buffering a suburban road network was also a tricky test for the old v.buffer. maybe it helps you as a test for the new version?
(spearfish or NC test datasets, or OpenStreetMap extraction)
2c,
Hamish
