[GRASS-dev] Re: SoC Report: v.buffer/v.parallel reimplementation
Росен Матев r.matev at gmail.com
Mon Jun 30 05:34:26 EDT 2008
Hi, Hamish
I have the "ditches test" on hand, but it contains areas and points as
I recall. I've not implemented nothing in v.buffer yet. I'm now
working on those parallel lines (to lines of course), which will make
implementing of v.buffer a piece of cake. Wait for a few more days,
and you'll be able to test the new modules. I'll update docs, since
there are new features and different cmd line options.
Rosen
On Mon, Jun 30, 2008 at 3:38 AM, Hamish <hamish_b at yahoo.com> wrote:
> Maybe a not very meaningful test, but how does it do with the previously problematic "ditches" vector from Maciek?
>  http://intevation.de/rt/webrt?serial_num=2765
> I recall that buffering a suburban road network was also a tricky test for the old v.buffer. maybe it helps you as a test for the new version?
> (spearfish or NC test datasets, or OpenStreetMap extraction)
> 2c,
> Hamish
