[GRASS-dev] Re: [GRASS-user] g.xlist/g.xremove addons (C version of
g.mlist/g.mremove)
Ivan Shmakov
ivan at theory.asu.ru
Mon Jun 30 00:22:06 EDT 2008
>>>>> Glynn Clements <glynn at gclements.plus.com> writes:
>> I've just uploaded g.xlist and g.xremove (C implementations of
>> g.mlist and g.mremove, no dependency on g.list/g.remove) to
>> grass-addons/general. To compile these addons, you need POSIX
>> regex(3) functions. They are super fast (native speed of
>> g.list/g.remove)! Please test these modules.
>> If these changes to libgis (ls.c, join.c, gisdefs.h, POSIX regex)
>> are acceptable, g.m?(list|remove) might be substituted with these
>> modules (?).
> The existing scripts cannot be removed unless the C versions can be
> made to work on all platforms (I daresay there's a regex library for
> Windows, but we still need configure tests, etc).
BTW, Autoconf allows for the parts of the package to be
configured by independent `configure' scripts
(AC_CONFIG_SUBDIRS.) Could the splitting of the top-level
`configure' script be considered for GRASS?
Doing the things this way has the following benefits:
* the move to Autoconf 2.50 could then be made gradually, and
not at once;
* when the part of code depends on a set of specific libraries,
there won't be any need to collect the specific compiler and
linker flags into specific variables -- they could be
collected into CPPFLAGS, CFLAGS and LDFLAGS (thus simplifying
the script), while they'll affect only the part of the package
the configure script belongs to.
