[GRASS-dev] quotong in messages [was: [GRASS-SVN] r30420
- grass/trunk/scripts/v.db.renamecol]
Maciej Sieczka
tutey at o2.pl
Wed Mar 5 09:49:31 EST 2008
Ivan Shmakov pisze:
> Hamish pisze:
>> It could very well be user error & bad memory on my behalf.
> It's probably so. It seems that `!' cannot be granted its
> special meaning within the non-interactive Bash (even with
> explicit `set -H'.)
>> But regardless it can only be a good thing to '' quote !s.
> I guess there're enough scripts with unquoted `!' outside of
> GRASS, and I believe that the special treatment of `!' violates
> POSIX. So, the only good thing for the user would be to fix the
> Shell.
Hi
So g.message manual is not correct:
Messges containing '!' and '$' must use single 'quotes' to avoid
unwanted shell translation.
It should be:
On the shell command line, messages containing '!' and '$' must use
single quotes to avoid unwanted shell translation of events and
variables. In shell scripts, both double and single quotes are safe.
Right?
Maciek
