[GRASS-dev] Re: GUI support for TclTk 8.5
Agustin Diez Castillo
Agustin.Diez at uv.es
Mon Mar 10 07:07:42 EDT 2008
I could try it.
On Mar 9, 2008, at 6:36 PM, William Kyngesburye wrote:
> I can build an OSX GRASS app with TclTk 8.5 for others to test, and
> try it myself.
> If we intend to support multiple versions of TclTk, it would be
> helpful to have a TCLTKVER variable in Platform.make for the
> configured major.minor version.
> On Mar 8, 2008, at 9:06 AM, Michael Barton wrote:
>>> IMO we should at least attempt to support Tcl/Tk 8.3 - 8.5.
>>> For 8.3 there is just the one problem with v.digit, AFAIK.
>>> For 8.5 it apparently mostly works, if it is just a few little
>>> issues
>>> which are not so hard to fix, then we should try and solve them.
>>> i.e. we should at least look into 8.5 problems, it is probably
>>> just 1-5
>>> lines of code to be adjusted, and that's not a huge drain on
>>> development resources.
>> You are right that fixing issues is probably pretty simple. It's
>> figuring out what to fix that is time consuming. Right now, I'm
>> heavily overcommitted timewise. And on top of that, I'm using my
>> laptop (primary development box) for my GIS class and can't afford
>> to have GRASS broken for more than a couple days. So I have no
>> problem in theory, fixing the GUI for 8.5 if it doesn't involve
>> NVIZ internals or something like that, but won't have time to do
>> much for awhile.
>> Michael
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> First Pogril: Why is life like sticking your head in a bucket filled
> with hyena offal?
> Second Pogril: I don't know. Why IS life like sticking your head in
> a bucket filled with hyena offal?
> First Pogril: I don't know either. Wretched, isn't it?
> -HitchHiker's Guide to the Galaxy
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
