R: [GRASS-dev] Re: GUI support for TclTk 8.5
marco.pasetti at alice.it marco.pasetti at alice.it
Mon Mar 10 08:23:42 EDT 2008
Hin
NVIZ works fine for me, with tcl/tk 8.5.1
BTW, I just finished the installer for windows, but there's still a problem I'm not able to fix:
installer procedure creates 4 different files to let GRASS work even if installed in dirs with spaces; files are:
grass63.bat
grass63 (to launch grass from msys shell)
msys.bat
grassrc6 (to avoid initial location error)
It works fine, but nviz fails if GRASS is installed in a "spaced" dir; I verified that error doesn't occur when installed in a "space free" dir!
I could release it right now (actually, after lunch ;-)), warning in the install procedure to not use dir with spaces, or delay the release and try to fix the problem.
What do you think about?
Marco
Da: grass-dev-bounces at lists.osgeo.org per conto di Maris Nartiss
Inviato: lun 10/03/2008 13.14
A: GRASS developers list
Oggetto: Re: [GRASS-dev] Re: GUI support for TclTk 8.5
Probably problem is mixed back and forward slashes within single call?
Please, open new ticket for this (hardcoded paths in nviz).
Maris.
2008/3/10, Paul Kelly <paul-grass at stjohnspoint.co.uk>:
> However, in a bit of further testing this morning I've discovered a new
> error that appears from different sources:
> couldn't duplicate input handle: bad file number
> while executing
> "exec $src_boot/bin/g.gisenv GISBASE"
> (procedure "Nv_makeGUI" line 13)
> invoked from within
> "Nv_makeGUI.top"
> (file
> "s:/grass/trunk/dist.i686-pc-mingw32\etc\nviz2.2\scripts\nviz2.2_script"
> line 1025)
> Paul
grass-dev mailing list
grass-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080310/b2dc1b08/attachment.html
