[GRASS-dev] [GRASS GIS] #84: scritps for converting raster maps
into GRASS 7 format, and back
trac at osgeo.org
Tue Mar 11 07:28:39 EDT 2008
#84: scritps for converting raster maps into GRASS 7 format, and back
Reporter: hamish | Owner: grass-dev at lists.osgeo.org
Type: enhancement | Status: new
Priority: minor | Milestone: 7.0.0
Component: default | Version: unspecified
Keywords: |
this is Gforge Patch # 372. I am moving it to the new trac system and
closing the patch on the Gforge system.
http://wald.intevation.org/tracker/index.php?func=detail&aid=372&group_id=21&atid=205
2007-04-18
r.convert and r.convert.all:
Converts a GRASS 4-6 raster map to a GRASS 7 raster map by moving files
around in the $MAPSET.
Mostly untested, probably misses some bits.
I did not use g.message as I think it should be fully backwards-compatible
with GRASS 5.0.0 and newer.
Tries to be really really cautious.
2007-04-18
minor fix for r.convert.all: give map name on error
2007-05-04
Note that the GRASS 7 raster format is still open for discussion,
this is just a trial for what it could look like.
It may be better to wait until the actual binary format changes
to do the rearranging.
This script + .tar.gz is probably a better way of doing a r.pack
script (see wiki addons).
Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/84>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
