[GRASS-dev] [GRASS GIS] #85: v.what.vect additional upload options
GRASS GIS trac at osgeo.org
Tue Mar 11 07:36:11 EDT 2008
 Reporter:  hamish       |       Owner:  grass-dev at lists.osgeo.org
     Type:  enhancement  |      Status:  new
 Priority:  minor        |   Milestone:  6.4.0
Component:  default      |     Version:  unspecified
 Keywords:               |
 I am moving this patch from the old Gforge patch tracker (# 374).
 I am still not sure if it is useful / meaningful to add.
 http://wald.intevation.org/tracker/index.php?func=detail&aid=374&group_id=21&atid=205
 Hamish
 2007-04-20
 Hi, I patched the v.what.vect script to allow other upload options.
 my needs changed & I don't actually need it now, so am not really sure if
 any of the add'l upload options are really
 needed/meaningful so haven't really tested or applied to CVS.
 maybe cat can be useful.
 modified version of version from CVS 20 April 2007 attached.
 Hamish
 Date: 2007-04-20 20:24
 Sender: Markus Neteler
 This seem to be the new functions:
 cat;category of the nearest feature;
 dist;minimum distance to nearest feature;
 to_x;x coordinate of the nearest point on 'to' feature;
 to_y;y coordinate of the nearest point on 'to' feature;
 to_along;distance to the nearest point on 'from' feature along linear
 feature;
 to_angle;angle of linear feature in nearest point, counterclockwise from
 positive x axis, in radians, which is between -PI and PI inclusive
 Date: 2007-06-07 04:50
 Sender: Dylan Beaudette
 These sound like useful additions. Why not put them in? I can
 test them in spearfish
 Date: 2007-10-17 02:54
 Attached the patch against current CVS. Please test.
Ticket URL: <http://trac.osgeo.org/grass/ticket/85>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
