[GRASS-dev] [GRASS GIS] #86: d.rast.edit: new script needs docs ported from old C module
GRASS GIS trac at osgeo.org
Tue Mar 11 07:47:41 EDT 2008
 Reporter:  hamish  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect  |      Status:  new
 Priority:  major   |   Milestone:  6.4.0
Component:  Docs    |     Version:  unspecified
 Keywords:          |
 this was doc issue # 406 on the old Gforge tracker. Moving it here
 there's a fancy new Tcl d.rast.edit module in CVS, but its
 scripts/d.rast.edit/description.html file is mostly empty.
 The relevant bits need to be "ported" from the old C version, in
 display/d.rast.edit/description.html. Lots
 of that will be irrelevant, so a straight copy is no good.
 e.g. explain what the aspect option is used for.
 thanks,
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/86>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
