[GRASS-dev] CELL/FCELL/DCELL [was: Re:
r.mapcal rand() strangeness]
Glynn Clements
glynn at gclements.plus.com
Tue Mar 11 22:27:52 EDT 2008
Maciej Sieczka wrote:
> >> I was going to add this information, but I'm not sure if I understand
> >> correctly that GRID3D is always floating point. Raster intro seems to
> >> suggest so, but r3.mapcalc suggests the opposite, eg.: "Note: If you
> >> calculate with integer numbers, the resulting map will be integer".
> >> Please tell me.
> > I suspect that's probably an artifact of verbatim copying from the
> > r.mapcalc documentation.
> > I'm fairly sure that G3D only supports FP.
> Can you confirm if double precision only?
G3D has both single and double precision formats.
> I guess so by experiments with
> r3.mapcalc - eg.:
> $ r3.mapcalc 'map=float(1)'
> $ r3.info map -t datatype="double"
Right. r3.mapcalc sets the in-memory representation appropriately, but
it doesn't set the file representation. AFAICT, it requires the
following change:
--- raster/r.mapcalc/map3.c (revision 30389)
+++ raster/r.mapcalc/map3.c (working copy)
@@ -588,6 +588,8 @@
void *handle;
int fd;
+ G3d_setFileType(res_type == FCELL_TYPE ? FCELL_TYPE : DCELL_TYPE);
handle = G3d_openCellNew(
(char *) name,
res_type == FCELL_TYPE ? FCELL_TYPE : DCELL_TYPE,
> > Looking at the r3.mapcalc code, the only way that you can get CELL
> > values from a 3D grid is if you use the various # operators to perform
> > colour lookups.
> It still yields double for me:
> $ r3.mapcalc 'map_g=g#map'
> $ r3.info map_g -t
> datatype="double"
You can't store CELL values in the output; they only exist internally.
E.g.:
r3.mapcalc 'map_g=g#map/2'
will only ever produce integers; you won't see e.g. 1.5 in the output,
as dividing two integers always produces an integer result.
Even with the above patch, writing an expression of type CELL to a G3D
map will result in a DCELL map (FCELL cannot accurately represent the
entire 32-bit integer range, as it only has a 24-bit mantissa).
