[GRASS-dev] compile an individual module
Martin Landa landa.martin at gmail.com
Wed Mar 12 11:57:14 EDT 2008
2008/3/12, roberto marzocchi <roberto.marzocchi at gmail.com>:
> I've to run configure  under  GRASS  directory?
yes, in the root GRASS source code directory.
Martin
> It's correct? Just for a module?
> thank you very much
> R
> 2008/3/12, Martin Landa <landa.martin at gmail.com>:
> > Hi,
> > > I've seen the howto:
> > > http://grass.itc.it/grass63/source/INSTALL
> > > I've  tryed with a script of add_ons (r.in.onearth),  I change the
> relative
> > > path
> > > in the Makefile to absolute path. (MODULE_TOPDIR=/mydirectory
> > > So it's stopped, because it don't such the file:
> > >  ($MODULE_TOPDIR)/include/Make/Grass.make
> > > ($MODULE_TOPDIR)/include/Make/Platform.make
> > > and "don't have the rule to make target
> > > ($MODULE_TOPDIR)/include/Make/Grass.make"
> > > so I've seen that the
> > > ($MODULE_TOPDIR)/include/Make/Grass.make don't exist,
> but
> > >  exists a ($MODULE_TOPDIR)/include/Make/Grass.make.in
> file,
> > > but I've correctly installed
> > you need to run configure with proper switches to generate Grass.make
> > and others.
> > Martin
> > Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
