[GRASS-dev] r.terraflow Windows patch
Glynn Clements
glynn at gclements.plus.com
Wed Mar 12 16:14:44 EDT 2008
Moritz Lennert wrote:
> >> > Can someone test the attached patch on Windows (MSys)?
> >> I now get:
> >> main.cc: In function `void record_args(int, char**)':
> >> main.cc:327: error: `ctime_r' undeclared (first use this function)
> > The attached patch should fix that issue.
> > If there are any remaining errors, please use "make -k", so that you
> > get all of them.
> Log attached.
The attached patch supersedes both previous patches, and should be
applied to the stock SVN source (either revert the previous patches
with "patch -R ...", or use "svn revert").
Index: raster/r.terraflow/main.cc
--- raster/r.terraflow/main.cc (revision 30536)
+++ raster/r.terraflow/main.cc (working copy)
@@ -324,8 +324,12 @@
exit(1);
+#ifdef __MINGW32__
+ strcpy(buf, ctime(&t));
+#else
ctime_r(&t, buf);
buf[24] = '\0';
+#endif
stats->timestamp(buf);
*stats << "Command Line: " << endl;
@@ -519,7 +523,8 @@
/* check STREAM path (the place where intermediate STREAMs are placed) */
sprintf(buf, "%s=%s",STREAM_TMPDIR, opt->streamdir);
- putenv(buf);
+ /* don't pass an automatic variable; putenv() isn't guaranteed to make a copy */
+ putenv(G_store(buf));
if (getenv(STREAM_TMPDIR) == NULL) {
fprintf(stderr, "%s:", STREAM_TMPDIR);
G_fatal_error("not set");
Index: raster/r.terraflow/common.cc
--- raster/r.terraflow/common.cc (revision 30536)
+++ raster/r.terraflow/common.cc (working copy)
@@ -18,7 +18,9 @@
#include <sys/types.h>
+#ifdef USE_LARGEMEM
#include <sys/mman.h>
+#endif
#include <ctype.h>
#if __GNUC__ > 3 || (__GNUC__ == 3 && __GNUC_MINOR__ >= 1)
Index: raster/r.terraflow/stats.cc
--- raster/r.terraflow/stats.cc (revision 30536)
+++ raster/r.terraflow/stats.cc (working copy)
@@ -21,7 +21,9 @@
#include <unistd.h>
#include <sys/time.h>
+#ifndef __MINGW32__
#include <sys/resource.h>
+#endif
#include <stdio.h>
#include <errno.h>
@@ -126,7 +128,9 @@
//ofstream that takes an fd; wrote another noclobber() function that
//closes fd and returns the name;
rt_start(tm);
bss = sbrk(0);
+#endif
char buf[BUFSIZ];
*this << freeMem(buf) << endl;
@@ -135,6 +139,9 @@
long
statsRecorder::freeMem() {
+#ifdef __MINGW32__
+ return -1;
+#else
struct rlimit rlim;
if (getrlimit(RLIMIT_DATA, &rlim) == -1) {
perror("getrlimit: ");
@@ -148,6 +155,7 @@
long freeMem = rlim.rlim_cur - ((char*)sbrk(0)-(char*)bss);
return freeMem;
+#endif /* __MINGW32__ */
char *
Index: raster/r.terraflow/IOStream/include/rtimer.h
--- raster/r.terraflow/IOStream/include/rtimer.h (revision 30536)
+++ raster/r.terraflow/IOStream/include/rtimer.h (working copy)
@@ -22,6 +22,38 @@
/* $Id$ */
+#ifdef __MINGW32__
+#include <time.h>
+#include <stdio.h>
+#include <string.h>
+#include <strings.h>
+typedef struct {
+ time_t tv1, tv2;
+} Rtimer;
+#define rt_start(rt) \
+ if((time(&(rt.tv1)) == ((time_t) -1))) { \
+ perror("time"); \
+ exit(1); \
+/* doesn't really stop, just updates endtimes */
+#define rt_stop(rt) \
+ if((time(&(rt.tv2)) == ((time_t) -1))) { \
+ perror("time"); \
+ exit(1); \
+#define rt_u_useconds(rt) rt_w_useconds(rt)
+#define rt_s_useconds(rt) rt_w_useconds(rt)
+#define rt_w_useconds(rt) (1.0e6 * (rt.tv2 - rt.tv1))
+#else /* __MINGW32__ */
#include <stdio.h>
@@ -48,10 +80,6 @@
perror("rusage/gettimeofday"); \
exit(1); \
-/* not required to be called, but makes values print as 0.
- obviously a hack */
-#define rt_zero(rt) bzero(&(rt),sizeof(Rtimer));
#define rt_u_useconds(rt) \
@@ -72,12 +100,16 @@
- ((double)rt.tv1.tv_usec + \
(double)rt.tv1.tv_sec*1000000))
+/* not required to be called, but makes values print as 0.
+ obviously a hack */
+#define rt_zero(rt) bzero(&(rt),sizeof(Rtimer));
#define rt_seconds(rt) (rt_w_useconds(rt)/1000000)
#define rt_sprint(buf, rt) rt_sprint_safe(buf,rt)
char * rt_sprint_safe(char *buf, Rtimer rt);
#endif /* RTIMER_H */
Index: raster/r.terraflow/IOStream/include/ami_stream.h
--- raster/r.terraflow/IOStream/include/ami_stream.h (revision 30536)
+++ raster/r.terraflow/IOStream/include/ami_stream.h (working copy)
@@ -36,6 +36,10 @@
#include "mm.h" // Get the memory manager.
+#ifdef __MINGW32__
+#define getpagesize() (4096)
+#endif
#define DEBUG_DELETE if(0)
// The name of the environment variable which keeps the name of the
@@ -421,7 +425,7 @@
// Get rid of the file if not persistent and if not substream.
if ((per != PERSIST_PERSISTENT) && (substream_level == 0)) {
- if (unlink(path) == -1) {
+ if (remove(path) == -1) {
cerr << "AMI_STREAM: failed to unlink " << path << endl;
perror("cannot unlink ");
assert(0);
Index: raster/r.terraflow/IOStream/include/quicksort.h
--- raster/r.terraflow/IOStream/include/quicksort.h (revision 30536)
+++ raster/r.terraflow/IOStream/include/quicksort.h (working copy)
@@ -41,7 +41,11 @@
// Try to get a good partition value and avoid being bitten by already
// sorted input.
+#ifdef __MINGW32__
+ ptpart = data + (rand() % n);
+#else
ptpart = data + (random() % n);
+#endif
tpart = *ptpart;
*ptpart = data[0];
data[0] = tpart;
Index: raster/r.terraflow/IOStream/lib/src/ami_stream.cc
--- raster/r.terraflow/IOStream/lib/src/ami_stream.cc (revision 30536)
+++ raster/r.terraflow/IOStream/lib/src/ami_stream.cc (working copy)
@@ -42,7 +42,11 @@
assert(base_dir);
sprintf(tmp_path, "%s/%s_XXXXXX", base_dir, base);
+#ifdef __MINGW32__
+ fd = mktemp(tmp_path) ? open(tmp_path, O_CREAT|O_EXCL|O_RDWR, 0600) : -1;
+#else
fd = mkstemp(tmp_path);
+#endif
if (fd == -1) {
cerr << "ami_single_temp_name: ";
Index: raster/r.terraflow/IOStream/lib/src/rtimer.cc
--- raster/r.terraflow/IOStream/lib/src/rtimer.cc (revision 30536)
+++ raster/r.terraflow/IOStream/lib/src/rtimer.cc (working copy)
@@ -18,7 +18,6 @@
-#include <sys/resource.h>
#include <stdio.h>
#include <string.h>
Index: raster/r.terraflow/IOStream/lib/src/mm_utils.cc
--- raster/r.terraflow/IOStream/lib/src/mm_utils.cc (revision 30536)
+++ raster/r.terraflow/IOStream/lib/src/mm_utils.cc (working copy)
@@ -17,7 +17,6 @@
-#include <sys/mman.h>
#include <ctype.h>
Index: raster/r.terraflow/flow.cc
--- raster/r.terraflow/flow.cc (revision 30536)
+++ raster/r.terraflow/flow.cc (working copy)
@@ -64,8 +64,12 @@
perror("time");
exit(1);
+#ifdef __MINGW32__
+#else
ctime_r(&t, buf);
buf[24] = '\0';
+#endif
*stats << endl;
