[GRASS-dev] r.terraflow Windows patch
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Thu Mar 13 09:10:41 EDT 2008
Compiles fine on MinGW/MSYS with an SVN checkout from an hour
ago. Can start the module and get help text. Don't know how to
use it so can't really test any further.
Best,
Benjamin
Glynn Clements wrote:
> Moritz Lennert wrote:
>>>>> Can someone test the attached patch on Windows (MSys)?
>>>> I now get:
>>>> main.cc: In function `void record_args(int, char**)':
>>>> main.cc:327: error: `ctime_r' undeclared (first use this function)
>>> The attached patch should fix that issue.
>>> If there are any remaining errors, please use "make -k", so that you
>>> get all of them.
>> Log attached.
> The attached patch supersedes both previous patches, and should be
> applied to the stock SVN source (either revert the previous patches
> with "patch -R ...", or use "svn revert").
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Benjamin Ducke
Senior Applications Support and Development Officer
Oxford Archaeological Unit Limited
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel.: ++44 (0)1865 263 800
benjamin.ducke at oxfordarch.co.uk
