[GRASS-dev] Re: [GRASS GIS] #94: PROJ file sometimes not created
	with location
    trac at osgeo.org
    Thu Mar 13 14:28:30 EDT 2008
#94: PROJ file sometimes not created with location
  Reporter:  cmbarton  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  major     |   Milestone:  6.4.0
 Component:  default   |     Version:  svn-trunk
Resolution:            |    Keywords:  location PROJ projection g.proj
Comment (by pkelly):
 Hello Michael,
 Please can you give an example of a file that causes this problem (put it
 online somewhere and post a link?) and I will investigate it. As far as I
 know any errors in parsing the projection information are reported. The
 only thing I can think of is that the file doesn't actually contain
 projection information - it's not an error to carry on creating a location
 from this though, as some information from the file (i.e. the extents and
 resolution) can still be used in creating the location.
 AND... as far as I can see g.proj already outputs a warning when an
 unprojected file is being used. Something like:
 Read of file ./roads.shp was successful, but it did not contain
 projection information. 'XY (unprojected)' will be used
 An additional warning could I suppose be added if a location is being
 created, specifically reminding the user of the need to run g.setproj or
 g.proj at a later date, if we think that's necessary. But I really need to
 see an example of the file that causes this problem as I can't see where
 it would be happening.
 Paul
Ticket URL: <http://trac.osgeo.org/grass/ticket/94#comment:1>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
