[GRASS-dev] r.watershed and swap memory
Hamish
hamish_b at yahoo.com
Tue Mar 18 21:38:44 EDT 2008
Yann Chemin wrote:
> 149,040,000 Cells for the srtm 90m of Mekong river.
> computer is on 8Gb RAM.
> About 65 % done after 43.x hours, r.watershed basically does it, it
> seems.
> Of course efficiency is a problem here, but it does it.
how much RAM is the process using? (check with `top`, VIRT RES SHR)
> yes r.terraflow goes to /tmp, that is considered a bug to me, not an
> enhancement...
> The location from which we have the GRASS dataset is generally the
> best guess for large empty Disk space.
note these r.terraflow options:
memory Main memory size (in MB)
default: 300
STREAM_DIR Location of intermediate STREAMs
default: /var/tmp
by making memory= larger the required tmp file space should be smaller.
you can set STREAM_DIR= somewhere else if you like.
Hamish
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
