[GRASS-dev] r.watershed and swap memory
Yann Chemin
yann.chemin at gmail.com
Tue Mar 18 22:21:21 EDT 2008
Hi Hamish,
my mistake, forgot to include that htop one:
VIRT 6323Mb
RES 5232Mb
noted the terraflow options, i am just waiting for this r.watershed
experiment to conclude...
Yann
On 19/03/2008, Hamish <hamish_b at yahoo.com> wrote:
> Yann Chemin wrote:
> > 149,040,000 Cells for the srtm 90m of Mekong river.
> > computer is on 8Gb RAM.
> > About 65 % done after 43.x hours, r.watershed basically does it, it
> > seems.
> > Of course efficiency is a problem here, but it does it.
> how much RAM is the process using? (check with `top`, VIRT RES SHR)
> > yes r.terraflow goes to /tmp, that is considered a bug to me, not an
> > enhancement...
> > The location from which we have the GRASS dataset is generally the
> > best guess for large empty Disk space.
> note these r.terraflow options:
> memory Main memory size (in MB)
> default: 300
> STREAM_DIR Location of intermediate STREAMs
> default: /var/tmp
> by making memory= larger the required tmp file space should be smaller.
> you can set STREAM_DIR= somewhere else if you like.
> Hamish
> ____________________________________________________________________________________
> Never miss a thing. Make Yahoo your home page.
> http://www.yahoo.com/r/hs
